Latest post 12-21-2011 6:40 PM by jjihonor. 4 replies.
Page 1 of 1 (5 items)
  • 12-11-2011 2:32 PM
    Struer Design Cabinet Dimensions
    Hi. Can anyone tell me what the dimensions are for the Struer Design cabinet for the Beovision 7-40?  Are the dimensions the same for the BV8-40 version?
  • 12-11-2011 3:42 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Struer Design Cabinet Dimensions
    Yes, the BV8-40 cabinet and 7-40 cabinet are exactly the same - except the 7-40 has the circular recess for the table stand.
    Smile
  • 12-11-2011 3:54 PM In reply to
    Thanks for that.  But do you have the dimensions (w x d x h)?
  • 12-16-2011 9:00 AM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    Yes, here you go!
  • 12-21-2011 6:40 PM In reply to
