Hello
I bought a Beocenter 5000 from eBay a while back and immediately fell in love with it. For the last couple of months it has worked fine (I only really use the turntable).
However, today whilst the power was on (and the PH was visible on the display) the turntable activated itself and the platter started turning. This is according to my wife, who was in the room. I don't have a B&O remote, but I did consider that the tv remote may have accidentally triggered it (which may be impossible).
Anyhow, this isn't the problem, the problem is now that the turntable won't stop revolving. The arm moves to the 7" position, then drops briefly, lifts and returns to the stop position, where it moves back to the 7" position and repeats the process again.
It does this with or without a record on the platter, and even continues when the unit is in stand-by mode. The only way to stop it is to turn it off at the mains. However, when switching the power back on it starts again. The 'stop', '33', '45' and 'turn' buttons don't do anything.
I am not particularly adept at repairing things, but am willing to have a go if this is fairly common and a relatively simple fix. However, I don't really know how to get into the deck to see whats going on! I've taken the platter off, but that's as far as I've got.
Please accept my apologies if this has been tackled before, I did try to use the search function but couldn't see anything.
If anyone has any tips, I'd be extremely grateful. Thanks in advance.
