Hello all.
I have just bought a new (to me) beovision 7 - 32
Looks amazing. It's my first bando but my family have had a few items over the years.
Took me a while but have got it set up.
The previous owner is sending the original receipt. I have it powered up but no pin code! I will try bando tomorrow for a master pin code. Otherwise it will be a work of art only.
I bought with PayPal and so all should be fine to return it should I not get a code.
Pham looking forward to using it....
Well I'm up and running, worked out the master code. I have no sound from the sound bar so assume it needs power (doh!). I have just one power cable but it's a female at one end and male at the other. I assume that it's the loop from tv to soundbar and that I need a new cable from the wall to the soundbar to power everything up??
Off to dealer to suss out how to get freesat and mk1 7.32 talking.
What speaker(s) have you got attached to the BV7...?
Michael
BV5, BV Avant, MX4000, MX1500
BS 7000, BS 5500
Penta III, Penta II, BL 4000, RL 60.2, RL 35, CX-100 Alu
BL 7000, MCP6500, MCP5500, BL 5000, Beo4 (x2), BL 1000 (x2)
Ok have used a power cable from an old DVD player. The speaker is a beolab 7.1
Sounds ok. Good enough for day to day use.
Hope to get to b&o shop shortly re cables etc for freesat...
Easley peasey - just scart and the little remote lead thing should I want to use it.
