Latest post 12-11-2011 2:09 PM by paultielen. 4 replies.
Page 1 of 1 (5 items)
  • 12-08-2011 3:35 PM
    Is it possible to connect my av 9000 to the mx 7000 with beolinkcable?
    Hello everyone, I'm the owner of the Av9000 and the mx7000. I will make a link with the beolinkcable between these television. The av9000 in Room 1 and the mx7000 in room2.. When i'm in room 2 i will listen music what's playing from the masterpannel..
    Is it possible?
    Thanks for all your comments :)
    Filed under: ,
  • 12-09-2011 2:47 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Is it possible to connect my av 9000 to the mx 7000 with beolinkcable?
    paultielen:
    Yes, but ...
    In any case you will need a BeoLink Video, a ML-cable, a ML-junction box and a
    7-pin DataLink-cable.
    The Master-Panel indicates, you have the very first AV 9000 version.
    These versions use a 16-pin ML-cable and have to be modified to be
    compatible to the recent 9-pin MasterLink-cable.
    Consult a B&O service technician.
  • 12-09-2011 3:50 AM In reply to
    Thanks, but do i really need all that cables. The only thing what i will do is listening music in another room.. nothing more.. There is not an option to plug the powerlink cable in bove of the television? Thanks..
  • 12-09-2011 4:59 PM In reply to
    • Vienna
    • Posts 712
    Yes, if you want to control your music in the room where the MX 7000 is installed
    in the same way as on your AV9000.
    PowerLink sockets on Tv and audio products are OUTPUTS sending sound to powerlik inputs
    of active speakers.
  • 12-11-2011 2:09 PM In reply to
    So, i can't connect them with only a powelinkcable?
