Latest post 12-08-2011 4:03 PM by Opman. 1 replies.
Page 1 of 1 (2 items)
  • 12-08-2011 1:08 PM
    • CJM1
    • Not Ranked
    • Joined on 09-01-2011
    • Posts 35
    Beosound Ouverture help
    I have my Beosound Ouverture set up to my Beolab 2000's, and when i press cd, tape etc the speakers dont turn on unless i press a source button on the remote or the play button on the speakers. is there anyway i can turn the speakers on by pressing a source button on the Ouverture?
    Smile
  • 12-08-2011 4:03 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: Beosound Ouverture help
    The BeoLab2000 is designed to be used in a "link room". It is not possible to operate the link speaker via the Ouverture keypad. You have to either use the buttons on the BeoLab2000 or direct the Beo4 remote to the BeoLab2000.
    Opman
