Thanks for your help Tommy, we've got that all set up but the Beo4 doesn't seem to do anything - sound, CD selection etc - is that what you meant by...
Just a note, the sound settings(volume, bass, treble, etc.) on the 9000
will not do anything with this set-up, but you probably wouldn't want
them to anyways.
It doesn't even allow CD selection which means the remote is useless. I've read a bit about changing options (0 to 1) etc...maybe this is what I need to do?
