Latest post 12-05-2011 2:23 AM by Sigmund. 1 replies.
Page 1 of 1 (2 items)
  • 12-04-2011 7:12 PM
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Overture and airport expess
    I would like to play my music via airport express through my old overture I know I can play it through the overture but I have two passive kits is it just a case of pressing a aux on the link rooms then using my iPhone to select the music!!
    Kai
  • 12-05-2011 2:23 AM In reply to
    • Sigmund
    • Not Ranked
    • Joined on 06-20-2007
    • Norway
    • Posts 46
    • Silver Member
    Re: Overture and airport expess
    Yes.
    You may want to place an external DAC between the Airport Express and the Ouverture to improve sound quality. In that way you use the digital output from Airport Express, eliminating its internal DAC which is quite mediocre.
    Sigmund
