Latest post 12-05-2011 2:38 AM by ECF. 3 replies.
Page 1 of 1 (4 items)
  • 12-04-2011 6:05 AM
    • ECF
    • Not Ranked
    • Joined on 03-28-2009
    • Posts 17
    Cover art and que in The New 2 way Beo 6
    Hi
    I have installed The New software but it does not work prefect. It does not display The Large coverart in The menu "whats playing now". I only see The Therese little ones in The "overview menu". I should also be able to press the large coverart and enter The playlist que. I can not!
    Anyone Else have this problem?
    //Erik
  • 12-04-2011 10:13 AM In reply to
    Re: Cover art and que in The New 2 way Beo 6
    Yes, exactly the same problem... don't know where to find the Play Queue browsing.
    BV7-40, BL9, BL4000, BL2000, BV6-26, Beosound 5, Avant70
  • 12-04-2011 9:26 PM In reply to
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Hold down the cover or press the plus sign
    I'm ready for something new that I actually want to buy!
  • 12-05-2011 2:38 AM In reply to
    • ECF
    • Not Ranked
    • Posts 17
    I know but it is not working. It just gives me The spinning wheel and nothing happends.
    //Erik
