Latest post 12-04-2011 9:26 PM by mjmedlo. 4 replies.
Page 1 of 1 (5 items)
  • 12-03-2011 3:02 AM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    BEO 6 Wireless with Time Capsule
    Anyone have this set up?
    I can't get it to work .. . .
    is there anything special?
    I'm ready for something new that I actually want to buy!
  • 12-03-2011 4:02 AM In reply to
    Re: BEO 6 Wireless with Time Capsule
    mjmedlo,
    Without a Beosound/Beomester 5 it wouldn't work. The Beomaster5 is the only device where the beo6 will work on.
    Also the Time capsule is not a DNLA device. So it won't work as a hard drive (NAS) for the BeoMAster 5
  • 12-03-2011 10:06 AM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    I have the bm5/bs5
    I'm trying to use the beo6 for 2way
    I can't get it to 'find' the bs5
  • 12-04-2011 3:21 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Check server ip in Beo6 wireless menu. It must the ip of your BS5 not airport/router.
    If the configuration of your Beo6 was made with an older CT (4.11?) delete Beosound 5 and replace it with the version in CT 5.12.
    I have no TC but My Beo6 World fine 2way with my airport extreme. So, if your BS5 does work 1way in your system the TC should be not the problem...
    Hope this helps
    Stefan
  • 12-04-2011 9:26 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    Yessir.
    Got it figured out.
    It's working like a charm now!!!
