Latest post 01-06-2012 11:24 AM by Stonk. 3 replies.
Page 1 of 1 (4 items)
  • 12-03-2011 2:49 AM
    • BegBeo
    • Not Ranked
    • Joined on 04-23-2008
    • Stockholm - Sweden
    • Posts 60
    • Gold Member
    BeoLab Penta 2 - Constant of green light and will not go into standby and no sound - Need help
    Hello, maybe someone of you have had the same error and can help me with a BeoLab Penta 2 is in constant of green light and will not go into standby, even if I try to shut it down manually are green lights left and does not extinguish, to turn off the Penta 2 that I have to unplug the power cord.
    OK, now it has a another error too, no absolutely no sound.
    You can hear a slight humming sound of the amplifier itself, but absolutely none of the speakers.
    Sincerely,
    Jan
    Filed under: ,
  • 01-06-2012 6:46 AM In reply to
    • BegBeo
    • Not Ranked
    • Posts 60
    • Gold Member
    Re: BeoLab Penta 2 - Constant of green light and will not go into standby and no sound - Need help
    Problem solvt it was TR BC337-40
  • 01-06-2012 10:10 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    if it is humming when on I would check the no-load current just in case it has drifted!
    Olly.
  • 01-06-2012 11:24 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    BegBeo:
    Hi Jan, thanks for coming back with the solution - always helpful for others in the futureYes -  thumbs up
    If you think nobody cares, try missing a couple of payments.
