Hi I've recently inherited my dads Beogram 1202. I've had the manual out and balanced the tone arm, set the stylus pressure and have records playing. The only issue is the automatic setting doesnt seem to work properly?
When I press the lift button with the switch in the 30cm position, the tone arm only swings about half a cm then lowers so its nowhere near the record. Also it doesn't lift when it gets to the end of a record no matter which setting its in, it just scratches right back across the vinyl?!
I downloaded the service manual and I went through the Downstroke info and attempted to alter the eccentric A & Bs though I'm not certain if they're in the right place, the wording and diagrams arent exactly clear to my novice mind!
Can anyone offer any info, tips, thoughts, diagrams or step by step instructions? Sorry if this has been asked before, I've had a look through the forums but couldnt see anything!
Please help! My vinyl is in desperate need of playing (and no further scratching!)
Cheers
Adam
