Latest post 11-30-2011 4:58 PM by loach1. 2 replies.
Page 1 of 1 (3 items)
  • 11-30-2011 12:51 PM
    • loach1
    • Not Ranked
    • Joined on 11-30-2011
    • Posts 3
    Hello and I have an impedance question for a Beocenter 9000
    Hi everyone,
    I am the lucky owner of a Beocenter 9000. It was a fixer-upper from eBay that needed the CD door mechanism to be fixed and the glass to be remounted. Now it works like a charm and is a great conversation piece.
    I am considering pairing it with some Magnepan MMG-W speakers because they solve some layout concerns and have the added benefit of producing sound for two adjacent rooms. I don't know if they will do all I would like, but I am pretty sure they will make me happy enough. The concern I have is that they have a nominal impedance of only 5 ohms. The Beocenter manual only mentions output at 8 ohms, so I am worried that the amplifier might get a bit hot. I don't plan on driving the volume too high, and I will probably supplement with a sub.
    Will the Beocenter be OK? I'd hate to break it!
    David
  • 11-30-2011 12:57 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Hello and I have an impedance question for a Beocenter 9000
    Hi there, and welcome to BeoWorld!
    I have very little know-how about the Maggies. Can you provide the speaker wiring details of these? More specifically, the small jumper/connection panel? If they are two-way then the band pass and high pass sections could be wired in series to increase the load... I don't think you will have any trouble in the first place, but this may be something to consider if a problem materializes.
    Evan
  • 11-30-2011 4:58 PM In reply to
    • loach1
    • Not Ranked
    • Posts 3
    Thanks for the reply Evan. From what I can tell, these small speakers are not bi-wirable. I think they just have a two wire pigtail coming out of one of the corners so they can be fed through the wall mounting bracket.
