Latest post 12-08-2011 10:13 AM by Sebastien. 2 replies.
Page 1 of 1 (3 items)
  • 11-30-2011 10:30 AM
    BeoCom5 / password reset
    Hi,can you please tell me about how to reset the password of my BeoCom5 base station? Sebastien
  • 11-30-2011 10:48 AM In reply to
    Re: BeoCom5 / password reset
    Sebastien,
    A Beocom 5 can be connected to BeoLine PSTN, BeoLine 1 or BeoLine 2 base units.
    A base reset can ONLY be done using a phone connected to the Beoline base.
    If you don't have at least one phone connected and working with the Beoline base you cannot reset the pin.
    Do you have at least one phone connected and working with your base ?
    Regards Keith....
  • 12-08-2011 10:13 AM In reply to
    Thanks Keith. I was away for a while. Yes, I do have another B&O cordless phone working with the base.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
