Latest post 12-01-2011 2:59 PM by stefan. 11 replies.
Page 1 of 1 (12 items)
  • 11-29-2011 2:40 AM
    BS5/BM5 not starting
    Hello!
    My combo BS5/BM5 doesn't want to start up - on the screen it shows "Bang and Olufsen" and the red dot is flashing! The soft-reset button on the BM5 does not show any reaction...
    The new software has been installed (automatically)
    The system (in combination with a BS9000 as audiomaster) worked fine until I copied some music (Beonet) the day before; I had to earse some music files as well; everything was working fine - I always check if music and coverart are working.
    Then I turned it off - the display went black but I could see that the background lighting was still on (I can not remember about the red light/dot); I tried a soft reset - no reaction; doing a hard reset (cutting power cord) the system went back again to: black display with red dot lighting - it seems to be fine but as I tried to listen to music nothing happend - again hard reset -> now as I wrote in the beginning...
    anybody any idea?
    Regards Elmar
  • 11-29-2011 3:27 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: BS5/BM5 not starting
    "Red Dot" indicates:  no ML connection established
  • 11-29-2011 4:12 AM In reply to
    Thanks for you quick answer....
    But I managed to make it worse: after a last soft-reset the system came up with the Windows Backupscreen where one could choose between "Beomaster5" and "Beomaster5Recovery"; I let it start up and the normal interface came up (where to choose betweeen N.music, n.radio, ... on the right and "mode", "artist", "cover", "title"... on the left -> problem was, that the wheel and other input gears of the BS5 did not react - so I did a soft-reset again and now the BS5 only shows the red light but there's no reaction turning the wheel or pushing the small button behind.
    I can hear the BM5 starting up (fan runs)
    I checked the cables - they are all in place...
  • 11-29-2011 5:59 AM In reply to
    Do you have image on the TV ? (if it is connected)
    If you use the remote , do you hear music ?
    Sometimes it takes some time after a reset before the system will react ...
    nico
  • 11-29-2011 8:35 AM In reply to
    I do not have a TV connected;
    it seems that there is no connection between the BM5 and the BS5 -> ok, some energy must be there because of the red light, but there is no reaction nether turning the wheel nor useing the remote
    maybe a cable has broken? but by starting the master there should be a "picture" on the screen...
  • 11-29-2011 9:22 PM In reply to
    • Vienna
    • Posts 712
    f5434964:
    ...after a last soft-reset the system came up with the Windows Backupscreen where one could choose between "Beomaster5" and "Beomaster5Recovery"
    DISCONNECT the BM 5 for SEVERAL (10-15) MINUTES FROM POWER  - reconnect the mains and
    when the black boot-screen lets you choose between "Beomaster 5" and "Beomaster 5 Recovery"
    select "Recovery".
    Be patient, don't disturb this process - it may take a while.
    During this process the unit may boot - be patient till the unit (hopefully)
    comes "back to live" again.
    After this you should trigger a "manual software update" to install the recent SW version again, and,
    as before, don't disturb ...
  • 11-30-2011 6:04 AM In reply to
    yes, I know I've some mistakes;
    there is no reaction at all; I also tried to connect a monitor to the DVI-output (no other gears connected) and again nothing on the screen; it seems that the HDD starts up also the red light turns to green but that's it;
    something seems to be "broken" ... no idea left
    Thanks for all your help - maybe if you have further ideas please let me know
    Regards Elmar
  • 12-01-2011 6:52 AM In reply to
    Does sort of hang then it keeps trying to boot up? ...if so could be the ram!
    Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
  • 12-01-2011 8:26 AM In reply to
    I'm afraid it's a hardware issue...ok, if done some resets but the BM5 is a kind of PC and there should be a kind of BIOS?!?!?
    now: plug in the BM I the led turns green and I can hear something starting up - I think its the HDD but nothing else is happening; the BS5 shows the red light but there is no reaction turning the wheel or pressing any button...
    with the on/off switch on the BM I can shut it down so the noise within stops and the led turns to red
    ... Sad
    I do not have any idea left what I could do - do not want to open it...
    elmar
  • 12-01-2011 8:52 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    I`m afraid you are right. If it`s an early BM5 - one of the first in 2009 - it might be a faulty mainboard. A known issue. My BM5 had a similiar problem and got a new mainboard - under warranty.
    Stefan
  • 12-01-2011 12:23 PM In reply to
    @Stefan thanks for your opinion - I think you're right; the BM is on its way to service; let's see what could be done...
    Problem: guarantee expired in Feb this year...
    Regards Elmar
  • 12-01-2011 2:59 PM In reply to
    • stefan
    • Posts 1,733
    f5434964:
    My BS5 is from Jan 2009. Warranty was expired too. Beo replaced the mainboard without any costs, because many mainboards in 2009 were faulty.
    Good luck....
    Stefan
