Latest post 07-13-2007 3:24 PM by Frank Rizzo. 14 replies.
Page 1 of 1 (15 items)
  • 07-12-2007 10:15 AM
    Powerlink "Y" 's....
    I've got the 2 back speakers (8000's) that are being used as rear speakers in a home theatre set up.....
    Do I have to run 2 separate Powerlink (8 wire).....runs from the A/V7000 to the back......OR.....can I make 1 Powerlink cable to the rear of the room and then add a "Y" there and to each 8000 speaker...???
    Thanks,
  • 07-12-2007 10:24 AM In reply to
    • 355f
    • Top 100 Contributor
    • Joined on 04-19-2007
    • Posts 655
    Re: Powerlink "Y" 's....
    Buy the Y adaptor from B&O in fact I have an unused one that I purchased some 4 months ago( as I have 4x8000 ) together with the thick 25 mtre powerlink lead  and if you like will sell it to you at half retail price! PM me if you want it!
  • 07-12-2007 2:59 PM In reply to
    Thanks Ferrari...nice ride..... ..i've got some "y"'s from before..... this project is in Colombia, S.A., so EVERYTHING...has to be shipped in......it's comming along..
     THanks again...
    K
  • 07-12-2007 3:01 PM In reply to
    355f, just to be clear....we're talking R and L...both coming off the same powerlink from the main unit...then putting a "Y" after the first (R) speaker and running that on to the (L) rear speaker?????
     Thanks, K
  • 07-12-2007 3:11 PM In reply to
    Every powerlink lead carries right and left information. You can use splitters as much as you like and you will still get right and left info. That's why the R and L switches are in the speakers.
    Regards Graham
  • 07-12-2007 3:53 PM In reply to
    • 355f
    • Posts 655
    mecca:
     Thanks, K
    Thats correct!
  • 07-12-2007 4:16 PM In reply to
    hey again guys...
    so...is there a physical switch on the speaker..??? or is it hardwired internally to only pick up the correct pin config. off the Powerlink??
    ALSO...this is for the REAR channel of the A/V 7000 surround sound processor.....!!!
    thanks,  k
  • 07-12-2007 4:27 PM In reply to
    Yes it has a Physical switch: Right, Left and Line. I think A/V 7000 only has Pro logic so the Rear plays mono normally, and only stereo in speaker 4...
  • 07-12-2007 4:37 PM In reply to
    Get the long Y powerlink 1,6m then it doesn't have to sit at the back of speaker (order n. 6270705)
  • 07-12-2007 5:04 PM In reply to
    The Y-adaptor would be an absolute no-go for me, in combination with a bl8000, unless I could hide it. There could be coming a (beautiful) rubber snake, coming out of the back of this speaker.
    Just solder, (or let somebody do it for you,) 2 powerlink-leads to 1 plug. Another option is using one lead for each speaker.
  • 07-12-2007 8:18 PM In reply to
    THANKS ~!~  That takes care of it....much appreciated...K
  • 07-13-2007 10:35 AM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Just out of curiosity, Keith. Do you have a nearby dealer in Colombia?
    Andy T.
    Poor me, never win owt!
  • 07-13-2007 1:42 PM In reply to
    Hi Andy,
    I live in the US part time and in SA part time...so everything goes to Miami and then it gets air freighted to Colombia.... It's time consuming and expesive...so you really have to think things out completely before moving...
    Greetings from Colombia....
  • 07-13-2007 3:03 PM In reply to
    What are the chances of meeting a Colombian here. I was born in Colombia, but have lived in the USA all my life. Good luck with the project.
  • 07-13-2007 3:24 PM In reply to
    Hey beo-ap,  Great!! What city?? I'm in Cali and Medellin....though the US now. We're doing a BS9000 connected to an A/V7000 on to Pentas and 8000's with a CX100 center speaker....then doing active and passive links throught. It's a learning experience..for sure..
    Do you travel back often?
