Latest post 11-27-2011 12:21 PM by mistercinder. 5 replies.
Page 1 of 1 (6 items)
  • 11-26-2011 2:51 PM
    beomaster 900K issue
    hi - just got a beomaster 900K - stereo works fine :-
    is it better for fm stereo repro to disconnect interior aerial and rig up a longer exterior one?
    when I first turned on the set the stereo light worked - now it doesn't - why?
  • 11-27-2011 2:08 AM In reply to
    • valve1
    • Top 500 Contributor
    • Joined on 05-27-2009
    • Dublin Ireland
    • Posts 213
    • Gold Member
    Re: beomaster 400K issue
    Welcome to Beoworld.
    mistercinder:
    Not sure what you mean by interior ariel but if you are getting all the stations you are looking for, stay with it. If your signal is weak or you are missing stations I would consider an external aerial.
  • 11-27-2011 3:13 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    You can check the lamp by selecting tape or phono where it will always be lit.
    If it doesn't, the lamp may have blown. (I can supply new lamps if needed, also for the dial).
    Not all Beomaster 900K had the stereo (MPX decoder) module installed.
    It was sold as an optional extra.
  • 11-27-2011 9:49 AM In reply to
    it is a 900K - it has the built in speakers (I also have the external speakers for the M model as I thought they might improve sound quality on mine)
    I am getting very good stereo repro which definitely changes to mono when I press the mono button
    when I initially plug in the unit and select the fm button the green stereo light comes on for about five minutes then it goes out - then I cannot get it when selecting tape, fm or phono - weird or what?
    I am getting good reception with the inbuilt fm aerial (two leads from lh socket go inside the set as per other blog pics)
    thanks for your help
  • 11-27-2011 10:01 AM In reply to
    • Dillen
    • Posts 5,008
    It could be as simple as a lose connection in the lamp socket.
    Try tightening the lamp slightly.
  • 11-27-2011 12:21 PM In reply to
    sounds likely - when I get the innards out I will check this
    I have a blue and blacl lead - I assume the black is live and blue neutral?
