Latest post 11-28-2011 3:36 PM by Oasis. 12 replies.
Page 1 of 1 (13 items)
  • 11-22-2011 1:27 AM
    BC2 socket uni wall bracket
    Does anyone know what the BC2 socket uni wall mount/bracket looks like? A pic will be even better!
  • 11-27-2011 9:15 AM In reply to
    Re: BC2 socket uni wall bracket
    There
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 11-27-2011 10:58 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Come on then, link?
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 11-27-2011 12:30 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    no pic - just a scan of a drawing...
    It's a moulded metal plate with clamps, holding the box "upside down"
    Sockets on the bottom side. Approx 5mm of distance to the wall.
  • 11-27-2011 4:31 PM In reply to
    stotty1111:
    Come on then, link?
    Don't know what happened there! I thought I'd posted a full description and recommended viewing the pdf in the BC2 Socket manual.
    Anyway, Vienna has posted a good picture. The prongs on the bottom of the plate go into holes on the bottom edge of the socket box.
    Graham
  • 11-28-2011 1:54 AM In reply to
    Does it come with the BC2? or do you have to order it separately??
  • 11-28-2011 2:28 AM In reply to
    • Vienna
    • Posts 712
    Oasis:
    It's in the package of the connecting unit.
  • 11-28-2011 2:29 AM In reply to
    You have to order separately.
    _____________
    Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
    1:st prize winner Beoworld January Price Draw.
  • 11-28-2011 2:38 AM In reply to
    • Vienna
    • Posts 712
    Hiort:
    Strange, when a friend of mine got his BC2 two years ago, the WB for the socket unit was included,
    the WB or stand for the Master unit must be ordered seperately.
  • 11-28-2011 3:14 AM In reply to
    Vienna:
    Hiort:
    My ex-demonstration BC2 came with the socket box and wall bracket. I had to make a separate purchase of a wall bracket for the BC2 itself (which otherwise sits on legs on a tabletop). Annoyingly, and typical of B&O, the B&O photographs of the wall mounted BC2 don't show any cabling, when in reality it's just about impossible to hide the thick cable and special plug that runs to the head unit. Even the hollow stem of the wall bracket is not designed to hide the cable. My cable now runs beneath a window sill and is carefully swept around the oval wall support base, so it looks OK if not invisible.
    Thinking about the socket unit again, I seem to recall that you locked all the connections into covered sockets on the unit, and that when you then dropped the unit onto the wall bracket that had the effect of securing everything: you then need to press some release clips if you want to lift the unit off the bracket to change any of the connections.
    Graham
  • 11-28-2011 4:32 AM In reply to
    Oh...I looked everywhere and I can't find the wall bracket for the socket unit. Actually i don't remember ever seeing it, maybe the installers threw it away with all the boxes when it was set up years ago as I didn't have any use for it...hmm
    I wonder if it can be ordered...or better if the dealer has a spare and can just give it to me!
  • 11-28-2011 8:06 AM In reply to
    • Vienna
    • Posts 712
    Oasis:
    B&O item# 3031047
  • 11-28-2011 3:36 PM In reply to
    Thanks.
    I hope I can find a 'free' one :)
