Hi:
Do as Martin suggests... start with capacitors.
Rectifier may or may not need to be changed. Earlier units had an underated rectifier, later ones seem to have had that problem corrected.
This may solve all of your problems so start there.
If still not well check for integrity of transistors on the touch switches.
I struggled on a similar problem for a while until I discovered that the one "master switch" transistor was (which turns on the whole until) was leaking.
After all this you should also replace all lightbulbs with exact replacements, but don't worry about this until you get everything working.
Derek
