Latest post 11-21-2011 7:22 AM by yachadm. 1 replies.
Page 1 of 1 (2 items)
  • 11-21-2011 7:17 AM
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    BeoCenter 9500 CDM4 doesn't spin up CDM2
    I have a BC9500 with a CDM4-33 (with Hall IC Turntable-Motor) in for restoration.
    The customer complains that the CD motor does not spin.
    I replaced caps on the Decoder PCB 31, and that is confirmed OK and functioning, tested in another machine (with a CDM2).
    On the Servo PCB 30 (with both Laser Current and Focus Offset potis), I replaced all caps, including C2103 (ESR measured 91 ohms!), with Vishay AML138 series.
    As per the SM, I set the R3105-3106 to 1KOhm, and then set the DMM probes on R3102. I connected AC, and the turntable rotated only a couple of degrees and stopped. Laser current voltage measures 1mV, and does not change with poti adjustment.
    So, I presume that the laser is shot. Below is a pic of the CDM4-33 laser, and below that is a pic of a CDM2-10 laser. They look almost identical.
    That part of the CDM4-33 laser does not look at all like the common CDM4-19 lasers available on ebay.
    Does anyone have any pointers on which laser to buy to suit the Servo PCB30, or I could even take a CDM2 PCB (with Laser current poti only) + CDM2 laser to replace the original CDM4 here.
    And, is there anywhere else I should troubleshoot on the Servo PCB 30 BEFORE connecting a brand-new expensive replacement laser?
    This is the first time I have not been able to rescue the laser on a BeoCenter (always a first time!), so for those of you with more experience than me in this area, I'd appreciate assistance.
    Additionally, for whomever is reading this - don't wait until your BeoCenter 8000-9500 fails - get the cap replacement done now, and prevent catastrophic failure like on this one.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 11-21-2011 7:22 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    Re: BeoCenter 9500 CDM4 doesn't spin up CDM2
    And this is the CDM2 which I connected to Decoder PCB 31 to confirm that that the Decoder PCB 31 was functioning fine after restoration
