David,
The following issues were fixed by version 2.2:-
- If a two-way CTV for example a 39XX and a one-way audio master like the Beomaster 5500 are placed in the central room, the MCL2AV is unable to detect the connection to a one-way audiomaster. This results in the following issues:-
Wrong volume level and wrong display read-out in x-tra active speaker room.
If an audio source is activated from an x-tra TV room, the volume will rise to 34. If BM 5500 has already been switched on, the volume should be raised to 10. If BM 5500 is in standby mode the volume should rise to 20.
- If BL 7000 is used for LOUDNESS operation in the active speaker room, incorrect status is displayed. When LOUDNESS is active, the BL 7000 display reads out "LOUDNESS OFF". When LOUDNESS is inactive, the BL 7000 display reads out "LOUDNESS ON".
Subsequently, the following issues was fixed with version 2.3:-
- Video sources in main room go into standby when TV in X-TRA TV room is operated.
- The system may become "locked" when LINK + A.TAPE is operated in option 4 (Link and audio master in the same room).
- Two-way operation of central video source in option 1 may cause 'No contact'
- Programming of central video source in option 1 is impossible.
- Set-clock from local TV-room. MCL2AV does not send the 'set-clock' information on to the other products in the system and the other clocks are therefore not set. The problem occurs with 'set-clock' on Beolink 5000 and Beolink 7000 but also when storing the text clock on the screen.
