Latest post 11-22-2011 3:28 AM by Large48. 5 replies.
Page 1 of 1 (6 items)
  • 11-20-2011 2:30 PM
    BEOLAB 150 & PENTA MK1 (Passive)
    Hello all enthusiast,
    I've got a pair of B & O  Beovox Penta Speakers. Would i be able to convert it into Active Speakers by connecting it to a Beolab 150 pls.
    What is the function of Beolab 150?
  • 11-20-2011 3:06 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BEOLAB 150 & PENTA MK1 (Passive)
    Partly.
    Beolab 150 is the amplifier section and adding a Beovox Penta will give you an active Penta speaker
    but it won't be a true Beolab Penta without the display and the large pentagonal shaped foot.
  • 11-20-2011 3:09 PM In reply to
    would i be able to use just 1 beolab 150 to power a pair of Beovox Penta?
  • 11-20-2011 3:41 PM In reply to
    It's a mono amplifier, so not really. You need a pair (as you would find on a pair of Beolabs) ideally. Probably easier to get some Beolabs or a better B&O amp, like a Beomaster 8000 or a Beolab 5000.
  • 11-20-2011 4:40 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    John is correct - you need a pair of BL150 amps plus the displays & wiring. In all honesty it will end up much cheaper & easier to simply buy a pair of Beolab Penta's - even if this means selling your Beovox's to fund this. The BL150 amps are the first ones used in the Lab penta range & were replaced with the BL200's & they are now starting to develop problems of their own.
    The only way it would make sense to buy the parts & upgrade a pair of Beovoxes is if they were in truly mint condition or if they had some sentimental value.
    Chris.
  • 11-22-2011 3:28 AM In reply to
    Or cheap, like £20 for a pair.................. :-)
    Train Hard - Run Fast - Hit to Kill!!!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
