Latest post 11-20-2011 3:05 PM by Dillen. 5 replies.
Page 1 of 1 (6 items)
  • 11-20-2011 12:20 PM
    • Wade
    • Not Ranked
    • Joined on 08-16-2011
    • New York, NY
    • Posts 12
    Beomaster 2400 won't power on
    I purchased a used Beomaster 2400 several months ago on eBay and it worked well for about a month (didn't have a chance to use it for a while after purchse). I re-arranged my furniture and unplugged the Beomaster in the process, now that I try to plug it in nothing will turn on. Trying multiple outlets has made not difference and I am at a loss as to what I can do to resolve this issue. Any ideas?
    Thanks!
  • 11-20-2011 12:46 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 2400 won't power on
    Is the red standby dot lit ?
    If not, have you flipped the power switch under the aluminum lid ?
  • 11-20-2011 12:54 PM In reply to
    • Wade
    • Not Ranked
    • New York, NY
    • Posts 12
    Yes, the power switch is on under the lid and no red dot is on by the stand by switch on the front panel.
  • 11-20-2011 1:49 PM In reply to
    • Dillen
    • Posts 5,008
    Then the fuses inside will be the next to check.
    Bottom plate off.
  • 11-20-2011 2:53 PM In reply to
    • Wade
    • Not Ranked
    • New York, NY
    • Posts 12
    Took the bottom off but I really have no clue what I'm looking at. Is there a tutorial that explains? Otherwise I would have to take it to some place in NYC to have it diagnoised and repaired.
  • 11-20-2011 3:05 PM In reply to
    • Dillen
    • Posts 5,008
    To be honest, for your own safety and also that of the Beomaster, if you don't know
    how to find the fuses, you better take it to a repairer.
    If it is indeed merely a blown fuse (that wouldn't be a first), it shouldn't be a very expensive repair.
