Right Guys
As I posted last week, my flat got flooded, with all my newly purchased Bang and Olufsen equipment in it. I think it was about two days before I found out that there was a burst pipe!!
So I'm guessing that my system had to endure about two days worthg of condensation!! So I removed the system the other day, and after turning it on, it kind of came back to life although a little bit ill. One of my Beolab Penta's was playing up the screen went blank and one of the bass drivers was blowing real bad. Luckily I had 2 spare ones, one of which I used and that solved that problem. After replacing the driver I put a hair dryer towards the circuit at the bottom of the speaker and after a while the screen came back to life. Some if not all my mid range speakers need refoaming (which will be done at a latter date) So thats the story of the speakers.
Now for the Master System, which has behaved a little bit differently. I used to before the flood run an Ipod through the phono socket, I did try teh aux socket but to no avail. It worked fine, tape 2 is also not working. When I got the system home from the flat, the ipod worked through the phono socket for a little while then just stoped, I tried to select with my Beolink 5000 but nothing, my CD works fine. Now I have plugged it into the Tape 1 socket and seems to be ok. But none of my other functions seem to be working everytime I set the bass and treble etc it has to reset once I turn the system on and off. Now I love my system and want to repair it!
So I ring up Bang & Olufsen of Harpendan and explain my problems he tells me its F***ed and to claim of insurance, no parts available!! His service was crap absolutly useless. The issue I have is that it sort of still works and all it needs is a repair. PLEASE HELP ME GUYS!! I can't seem to get a beo 4 to work the system either. Am very annoyed and frustated. What do I do? Would it be advisable to get some help from one of the technical guys here on the forum? I think my system is due a service? recapping etc
One very Pissed Off Nidul
5 Avant 28" VCR, 2 Silver, 2 Black, 1 Red/Burgandy ;-)
2 Avant 32" VCR, 1 silver, 1 Red/Burgandy
BeoVision MX1500 Black
Beovision MX4000 in Blue with Matching VCR
Beovision MX7000 in Grey with Matching VCR and Active Speakers
1 BeoCord VX7000 VHS VCR
Beocom 1401 with 2 AV Control base
BeoSystem 7000; BeoMaster 7000, BeoGram CD7000, BeoCord 7000 Cassette Deck.
1 Attyca Stand
BeoLink 1000, BeoLink 5000, 1 MCP 5500, 6 Beo4
2 Penta II, 2 RL 45.2
I-Pod Connection!
Trying to MasterLink It all!
