Latest post 11-17-2011 7:36 AM by stefan. 5 replies.
Page 1 of 1 (6 items)
  • 11-16-2011 8:17 PM
    • Chris
    • Top 500 Contributor
    • Joined on 05-09-2010
    • Last of the Summer Wine Country, Yorkshire, UK
    • Posts 195
    • Gold Member
    IRtrans Translator
    Does anyone know the function of the IRtrans Translator? When would it be used? It is B+O 455mhz compatible.
    http://www.irtrans.de/en/shop/translator.php
    Beosound 8, Beotalk 1100, Beocom 4, A8 Headphones, Form 2 Headphones, Apple iPhone 4S, iPod Classic, iPad 1, Sky+ HD, Sony Playstation 3, Jacob Jensen T10, Lutron Rania IR Dual Dimmer/ Accesory dimmer, B+O A9 Keyring (SOLD), Beolit 600 (SOLD), Apple Airport Express, Beo5
  • 11-17-2011 2:48 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: IRtrans Translator
    Search the forum.... you will find all the information you need.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 11-17-2011 3:47 AM In reply to
    Chris:
    The IRtrans is compatible with the B&O 455 Khz (not Mega Hz) carrier frequency and several members use this product.
    Regards Keith....
  • 11-17-2011 5:57 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    The IRtrans can receive and transmit Beo codes. I tested this product years ago, but I switched to the Lintronic box, because it`s more flexible.
    Can be contoled and control IR (incl. Beo commands), switches, X10, RS232...It can even be triggered by datalink from Beo Scart sockets to control 3rd-party devices like stb, BD players, mediaplayers.It can also contol Beo commands in a MCL linksystem via an MCL2A (AV)
    You can program macros and use the new LIGHT and CONTROL functions of the nwéw Beo4 navi.
    My son is controling all his stuff - Samsung TV, Digiality stb, xbox, BM3300, BG3300 with Beo4 via a Lintronic box using macros.
    My cinema setup is controled by a Lintronic box via the cinema socket on my BV7-40. My blinds are controled by a relay box 108 also made by Lintronic.
    And they have an online database for IR codes.
    Stefan
  • 11-17-2011 7:20 AM In reply to
    • Chris
    • Posts 195
    • Gold Member
    Do you know the cost of the linktronics box ? Thanks
  • 11-17-2011 7:36 AM In reply to
    • stefan
    • Posts 1,733
    See:
    http://lintronic.dk/TT455-RT-238.htm
    Stefan
