Latest post 11-15-2011 4:21 PM by stringbag. 2 replies.
Page 1 of 1 (3 items)
  • 11-15-2011 4:36 AM
    Beocentre 6-26 DVI no picture in 720p but ok in 576/480p
    Hi all.
    I have a Beocentre 6-26 running software version 9.2
    I have also just bought a Panasonic DMR-BWT700 Freeview HD pvr & Blueray player and can't get the DVI signal to show properly.
    It works fine (although squashed) in 576p/480p but absolutely nothing when 720p selected. The volume does not even show (b&o volume, when adjusted on the Beo4). No b&o menu, nothing. Reslect 576p/480p and it all returns to normal.
    I borrowed an LG freeview HD tuner from the store and that does exactly the same.
    Any ideas?
    Thanks very much
    Beocentre 6-26, DVD1, beolab 3500, beocom4, beotalk 1100.
  • 11-15-2011 12:18 PM In reply to
    Re: Beocentre 6-26 DVI no picture in 720p but ok in 576/480p
    Are you sure your BC is HD Ready?
    Does it have component connection?
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 11-15-2011 4:21 PM In reply to
    Yes, All the BC 6 are HD ready - just the early BV6s that were not.
    Yes, have component but not tried it (don't have a cable!) - the DVI input definitely works but just not at 720p. (If I select HDTV in the menu system of the BC6 I have the choice of either 'YPBPr', 'DVI' or 'No').
