Latest post 12-05-2011 4:48 AM by Søren Hammer. 2 replies.
Page 1 of 1 (3 items)
  • 11-15-2011 1:08 AM
    • wolfram l
    • Not Ranked
    • Joined on 09-14-2011
    • los ángeles
    • Posts 2
    Beomaster 8000 + Boston active Subwoofer
    Hi B&O community!
    After restoring my Beomaster 8000 with new Caps in the output stages and solving a nasty problem with the 7805 voltage regulator on PCB 6, everything works flawlwssly now ! Thankos to Martin again for the Cap Kit that got me started.
    Since I have an active Boston Subwoofer sitting around, I was wondering howI could connect it to the Beomaster. I would need a variable line out, since the subwoofer only has a stereo line in or lfe connection. I know, there is the possiblity to connect a line out converter to the speaker connectors directly, but i don t wanna do that.
    Yourhelp is very much appreciated!
    best, regards, Wolfram
  • 12-05-2011 4:38 AM In reply to
    Re: Beomaster 8000 + Boston active Subwoofer
    Hi Wolfram
    Does the Beomaster has the same LINE IN / LINE OUT Connector as the Beomaster 6000? If yes, you could connect your subwoofer there, using a special connector which still provides the IN/OUT-Connection.
    Otherwise, you could change the DIN-Plug for TAPE 2 (if not in use) from a constant line out to a variable line out. I have no service manual of BM8000 at hand to tell you where to find the variable line level on the board (service manual should be in the beoworld documentation).
    Good luck
    David
  • 12-05-2011 4:48 AM In reply to
    The Tape 1 output has two RCA-plugs which can be used as a line out, otherwise, a loop involving the Pre-amp out and Power-amp in could be considered as the filters won't be active from the tape output.
    Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
