Latest post 11-15-2011 5:05 PM by Steffen. 3 replies.
Page 1 of 1 (4 items)
  • 11-14-2011 10:10 PM
    Beosund 3200
    I have a real dumb question. Can i connect my beosound to an amp using the powerlink cable and then use some technic speakers that i have connected to the amp. I can't find cheap active B & O speakers. Please help
  • 11-15-2011 5:32 AM In reply to
    Re: Beosund 3200
    The answer is probably.
    There is a sister site called BeoTech ... take a look at the wiring diagrams there and your can probably devise a solution.
    Alternatively Steve at SOUNds HEAVENLY (see advert at bottom of the Beoworld pages0 may be able to work up something for you.
    We recommend Steve because he is a good guy and sponsors BeoWorld :-)
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 11-15-2011 7:15 AM In reply to
    • Paul
    • Top 500 Contributor
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    Re: Beosund 3200
    Beolab 2500 wil cost you about 300 euro's. An other alternative is Philips motion feedback speakers these works very well on the PL of Beo products
  • 11-15-2011 5:05 PM In reply to
    Re: Beosund 3200
    There is a German company called DeToma. They make amplifiers with a Powerlink input socket and standard speaker terminals. Then you can use any passive loudspeaker you like.
    Ofcourse you can also try and find a secondhand B&O MCL 2P amplifier.
