Latest post 11-12-2011 9:17 AM by folkdeejay. 1 replies.
Page 1 of 1 (2 items)
  • 11-12-2011 1:37 AM
    • synth
    • Not Ranked
    • Joined on 10-31-2011
    • Posts 18
    Odd DVD1 behaviour
    Getting a dvd to eject is becoming a bit of lottery. Sometimes it will eject cleanly, sometimes it wont. I'm operating the player from the front panel as its playing back into a sony tv. Its been fine for about 12 months.
    I see on the screen in the little message box its says "opening" as the tray opens, then it then says "Blocked!" once the dvd tray is fully open - can anyone tell me if this "blocked" is by design and what it might mean please?
    I tried a few DVDs and they DVD play back, but play back was becoming a bit erratic with freezes occasionally or jumping.
    I put  DVD cleaner disc in and it didnt make much differnece. I'm not sure if its a sensor thats maybe blocked up by dust etc.
    Or is perhaps its time to get it looked at?  Its a great machine when its running well.
    ANy thoughts welcome.
    S.
  • 11-12-2011 9:17 AM In reply to
    Re: Odd DVD1 behaviour
    I assume you have unplugged it for 10 minutes or so ?? - just in case it has got muddled.  Long shot but you never know.
    Without being too opportunist, if its letting you down, you could consider a replacement - as it hapens i just listed mine on ebay, see here
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130600555170
    Wink
