Latest post 11-12-2011 5:25 AM by Nio. 3 replies.
Page 1 of 1 (4 items)
  • 11-11-2011 7:07 PM
    • Nio
    • Not Ranked
    • Joined on 10-01-2011
    • Posts 61
    Beogramm 7000 -> Beosound5 (+Master)?
    How to connect a Beogram 7000 to a BeoSound 5 inkl. beomaster 5 so that you can listen to the beogram also in the link rooms and control it with the beo4 reomote?
    THANKS!
  • 11-11-2011 11:27 PM In reply to
    Re: Beogramm 7000 -> Beosound5 (+Master)?
    Just have a look at Steve's website (soundsheavenly), he has the solution for you..Look for "BeoMaster 5 aux." Smile
    Reunion Island is greeting you!
  • 11-12-2011 3:27 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Nio:
    ... so that you can listen to the beogram also in the link rooms ...
    Possible if BeoMaster 5 is the audio master of your ML system.
    Nio:
    ... and control it with the beo4 reomote?
    As the BM5 has only an USB and no DataLink enabled input, you will not be able
    to control the turntable by a remote - only manual operation possible!
    As already mentioned by Chris, you'll need some parts from Sounds Heavenly:
    - an analogue <> digital AUX input converter
    - and an adaptor cable to connect the DIN 7pin (BG7000) > 2x RCA/Cinch/Phono (converter)
  • 11-12-2011 5:25 AM In reply to
    • Nio
    • Not Ranked
    • Posts 61
    Ok, thanks ... So if a buy an overture for example I can connect the BeoGram with Dtalink to the overture and the Overture with masterlink to the rest of the system.
    Version 2.1 can be a slave even in the main room and I can listen to beogram in the linkroom?
