hello,
on the case i have one question the beosound 2 does not fit well - i mean the entire rubber pad with controls does not seat very well.
aint sure if it has got to do with craftsmanship. alternatively can i check if this genuine or 1st class imitation?!
the button for fastening the upper flap seems to be different in the media centre files of B&o (google Beosound2 Backgrounder) will take you through the PDF link -- i am finding difficult to embed the link here
FYI - i recently picked this on e-bay
regards
pattabhi
