Latest post 11-14-2011 12:49 PM by Dean. 3 replies.
Page 1 of 1 (4 items)
  • 11-09-2011 8:50 AM
    • Dean
    • Not Ranked
    • Joined on 09-03-2009
    • Posts 13
    BeoVision 7-32 to Apple TV 1st Gen CONFIG HELP! ! !
    Hi, I have a beovision 7-32 and want to add apple tv. I have just managed to get the 1st gen version as built in hard drive, however my tv does not have a hdmi socket so I am going to opt to use the compoment and rca for sound. I am aware you can get a hdmi to dvi cable and then add sound via the rca but doing this will not drive the beo4 remote?
    However how do I programe and control this from my beo4  remote, I had my tv puc flashed with the apple reomte software, please help
  • 11-09-2011 1:03 PM In reply to
    Re: BeoVision 7-32 to Apple TV 1st Gen CONFIG HELP! ! !
    I would use component connection instead of DVI.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 11-11-2011 9:23 AM In reply to
    Hi - I have one connected to my Avant - so not sure about yours but on mine I have a SKY box connected to one scart as SAT (STB) and on the Apple TV I have it connected as V.AUX (STB) the third socket takes the DVD. When you press ok after assigning the connection you then have to specify type of STB so it was Sky TV and yours will then be Apple for V.Aux.
    I couldn't use RGB as the Avant won't support it so bought an HDMI to Composite converter and sound and vision both come out of that into the Avant. I did try experiementing with using the optical output through a converter but the Avants card will only seem to work with the SAT and DVD sockets.
    Hope this helps
    Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
  • 11-14-2011 12:49 PM In reply to
    • Dean
    • Not Ranked
    • Posts 13
    tHANK YOU i HOOKED IT UP OVER THE WEEKEND,
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
