Latest post 11-27-2011 11:33 AM by spuns. 2 replies.
Page 1 of 1 (3 items)
  • 11-09-2011 7:34 AM
    • spuns
    • Not Ranked
    • Joined on 11-09-2011
    • Posts 2
    export a Itunes playlist to BS5 Encore
    does anyone know whether it its possible to export itunes playlists to BS5 Encore. I have converted my Itunes playlists to .m3u format which is recognized by twonky media server they are, however, not showing up on the BS5 Encore !
    thanks
    Filed under: , ,
  • 11-27-2011 2:28 AM In reply to
    • PentaIII
    • Top 500 Contributor
    • Joined on 04-26-2007
    • Australia
    • Posts 83
    Re: export a Itunes playlist to BS5 Encore
    Would be great to be able to do this than spend hours trying to create playlists on the  system itself.
  • 11-27-2011 11:33 AM In reply to
    • spuns
    • Not Ranked
    • Posts 2
    Yes doing it on the Encore itself is a rather tiresome process - and as far as I know you cannot remane the playlists from "RED" to eg. chrismas music. It would be great with a piece of B&O software where you can manipulate your music library on your computer rather than on the Encore.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
