Hi everybody
I want to use a beosound 2500 or my beosound 4 as a preamp to a pair of acoustic reality ear 1001 (icepower 1000 asp inside).
I will use a powerlink to RCA cable.
THe icepower amps need low impedance.
I tried with the preout of my yamaha rxv 861 but the impedance is too high (1.2kohms).
The sounds is good but on high frequencies, I should see some difference with another preamp.
Any ideas?
If you can advise me an affordable preamp with a low output impedance, it could be great too.
Thanks in advance
Best regards
oLivier
