This would be a completely different problem on the Encore, which doesn't run on Windows XPE.
AFAIK (I read it here somewhere) the Encore is using Linux - it should have no problems recognizing any drive you connect to it on the hardware level, but that won't get you anywhere if you can't access it. You won't be able to run any extra programs or do anything else B&O didn't want you to do. (unless it is actually some kind of an embedded PC and it's possible to boot it with a rescue image off an USB stick and start hacking... )
Anyway, IMHO this is all quite academic. Maybe some hardcore BM5/BS5 user might get by without any computers to do the ripping, but I don't think an Encore would find its way into such a household!
