1st March February 2012
Latest post 11-05-2011 9:49 AM by Leslie. 8 replies.
11-03-2011 10:44 PM
Nidul
- Joined on 10-22-2011
- Hitchin, Herts
- Posts 79
Guys I have connected an Ipod to my Bm7000, it does sound nice through my Penta's but I have a problem and that is, at low volume the sound quality is not great? It sounds like the speakers are kind of farting, sorry thats the only way I know describing the sound. Do I need to replace all the driver foams? Are these any good?
http://www.ebay.co.uk/itm/8x-Foam-Surrounds-Bang-Olufsen-Penta-/360246356743?pt=UK_AudioVideoElectronics_HomeAudioHiFi_HiFiSpeakers&hash=item53e05b2b07
Thanks In Advance Nidul
5 Avant 28" VCR, 2 Silver, 2 Black, 1 Red/Burgandy ;-)
2 Avant 32" VCR, 1 silver, 1 Red/Burgandy
BeoVision MX1500 Black
Beovision MX4000 in Blue with Matching VCR
Beovision MX7000 in Grey with Matching VCR and Active Speakers
1 BeoCord VX7000 VHS VCR
Beocom 1401 with 2 AV Control base
BeoSystem 7000; BeoMaster 7000, BeoGram CD7000, BeoCord 7000 Cassette Deck.
1 Attyca Stand
BeoLink 1000, BeoLink 5000, 1 MCP 5500, 6 Beo4
2 Penta II, 2 RL 45.2
I-Pod Connection!
Trying to MasterLink It all!
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Post some pics of your surrounds, the problem may be the your Ipod library, if your music is low Kbs files the problem may be there.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Nidul
- Hitchin, Herts
- Posts 79
Hi Soren
I am pretty sure I have Beolab Penta II, I know I need to change the foams, but am worried as I have never done this type of thing before! I a pretty good at doing fiddly jobs like this but am not sure wheather I trust myself. Firstly how do I get the old foam off the speakers then is it just a case of glueing the new ones in place? These are my questions/worries. Is it pretty easy? And should I buy that kit I have seen on Ebay, that includes foam replacement aswell as Fret material? The issus wants e to place the old grey Frets with some fresh black Frets!!
Hi Leslie
I will get some pictures up as soon as I get my camera back from the missus. Hope you are well? I am about to hunt down your Workbench thread about the White BeoSystem 6500. I am very Interested because I want to buy a complete set very similar! I also want to get beolink 7000 and floor stand, do you know where I could get one of these? I did think about the Ipod recording format/levels, so it could be that, but I defineatly think the foams need replaceing.
Thanks for all your help and advice guys! Nidul
1 Attyca Stand
I-Pod Connection!
langleyav
- Joined on 05-03-2007
- London, UK
- Posts 41
Try this website for replacement foams, and they do a good video showing how easy it is to do. I refoamed my CX50's and the difference is truly amazing. The process is not too difficult but if you are carefull the results are very rewarding.
http://www.goodhifi.com/
Ron
Nidul
- Hitchin, Herts
- Posts 79
Ron
Thank you for that, I will have to replace foams when funds get easier, but with xmas around the cornor, I don't know when it will be.
Nidul
1 Attyca Stand
I-Pod Connection!
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Nidul,
It is worth doing a search on the forum about the refoaming process, there is a lot to it. There is a lot of material on BeoWorld about this. These threads should answer your questions.
dmacri
- Joined on 05-03-2008
- Posts 63
I'll second the replacement foams from goodhifi. I've been able to repair about a dozen speaker pairs without issue using his foam surrounds. Take your time, work slowly and carefully. The video shows exactly how to do it. I use a battery to help center the woofer in the voice coil gap. Never had a problem.
BeoSystem 5000 (BM 5000, BG 5005, BC 5000, CD50), BeoCenter 3500, BeoCenter 2500, BeoLab 2500, BeoVox S-45, S-45.2, RL-140, CX-100, CX-50, C-75, 3 MCL82 link rooms, A8, 4001 relay and ambio
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Nidul:
Hi Leslie
Got them all PM me
Refoaming Penta drivers? No sweat...
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Page 1 of 1 (9 items)
