Latest post 11-07-2011 6:25 PM by Harry2008. 1 replies.
Page 1 of 1 (2 items)
  • 10-30-2011 1:40 PM
    Macbook pro to connect with Beosound 5 / Beomaster 5
    I bought my BS5/BM5 in 2009 and did run it with my Windows PC. I changed over to Apple ( Macbook pro and Lion ) recently. I have now installed the Beoconnect for Apple on my Macbook pro but get only the " grey " B&O symbol on the dock, nothing gets connected.
    Not sure whether I did a mistake while installing Beoconnect or whether it does simply not function with the latest Lion OS?
    Anybody can help me?
    Regards wmaier
    Filed under:
  • 11-07-2011 6:25 PM In reply to
    Re: Macbook pro to connect with Beosound 5 / Beomaster 5
    I got the same issue. The problem is the SMB deactivation in Lion.
    What you can do is use finder to connect manually to the BM5. Type:
    • cmd+K  (or go Finder -> Go - Connect to server)
    • in the dialog type  smb://<ip number of your BM5>
    After connecting, a prompt to enter a username and password will be displayed. Enter these and there it is... the directory structure of your BM5 in a finder window.
    In the BeoConnect application you will than see the BM5 as well. At it, click once on it and enter the password and it will work again.
