Latest post 07-12-2007 2:57 PM by Frank Rizzo. 9 replies.
Page 1 of 1 (10 items)
  • 07-10-2007 7:24 PM
    Beolink ACTIVE IR EYE wiring..
    I've got to run an IR (hockey puck) eye for about 60 feet....I've got regular CAT 6 .....NOT the STP...just regular  CAT 6.....
    The IR eye has 4 wires connected for the Active Kit....
     Can I just use the CAT 6 for the runs??
    Thanks,
    Keith
  • 07-10-2007 8:03 PM In reply to
    Re: Beolink ACTIVE IR EYE wiring..
    I don't think you can do that, the cable for the eye is a special low capacity cable, comes in 5 and 15 m (15 and 90 feet I think). 5 wires.
  • 07-10-2007 11:36 PM In reply to
    • Chris
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Bredene near Ostend-Belgium
    • Posts 143
    hmm, I would for sure give it a try before placing it. Just solder the plug on the wire and mount the IR on it, just to see if it works. Cat6 is low on capacity.
    Yes, I kown my spelling is horrible… Huh?
  • 07-11-2007 10:20 PM In reply to
    Marcus...you're our CAT 6 hero........any idea if I could use a CAT6 normal (not STP) to wire in an IR (hockey puck) eye....????
     Thanks, K
  • 07-12-2007 1:54 AM In reply to
    Using the normal wire, no more than 5m is recommended. To use more, the low capacity receiver cable, part number 6270668, is available up to 15m. Details in the ML handbook which is on site,
  • 07-12-2007 2:55 AM In reply to
    mecca:
     Thanks, K
    Hi Keith,
    many thanks for the laurels :-) but unfortunately I have absolutely no experience with the IR eye. Had a BL active some time ago, but as it has been lying around for some years I sold it, so I have no material to do a test :(
    Do you have some spare cat6 cable to make a test?
    Sorry that I can't be of much help here....
    Marcus
  • 07-12-2007 9:26 AM In reply to
    Thanks guys for all the help......
     Does anyone know if CAT6 is "low capacity" similar to the cited BO part number??
    Thanks, Keith
  • 07-12-2007 10:23 AM In reply to
    Keith,
    I think your biggest issue with using any of the CAT cables is that they are twisted pairs intended for balanced digital signals to reduce noise.
    The cable which goes to the IR contains parallel stranded wires of low capacity. If you were to use 6 core alarm cable in my view you should be just OK. A typical example is alarm cable found at Maplins which you can see HERE
    Regards Keith....
  • 07-12-2007 12:42 PM In reply to
    • frog
    • Joined on 04-19-2007
    • Posts 191
    If it is any help, I am using one connected with 15m of regular cable - although only +5v, signal and ground connected.
  • 07-12-2007 2:57 PM In reply to
    Thanks Keith....looking into this now.......much appreciated..
    Keith
