Latest post 10-25-2011 10:48 AM by Vienna. 1 replies.
Page 1 of 1 (2 items)
  • 10-25-2011 5:50 AM
    • Noah
    • Top 500 Contributor
    • Joined on 12-16-2008
    • Switzerland
    • Posts 120
    • Silver Member
    Beocenter 1 Timer
    Hello everybody. I hope you are all good.
    I have a question which I posted in the german forum but nobody seems to have a clue.
    I recently bought a immaculate Beocenter 1. This Beocenter does not have the timer function which I would like to use. What do I need to do to get the timer working. Has it something to do with this ML card? Can I make a software update? The software is 3.0. Type is 8510.
    I hope somebody can help me.
    Regards, Noah
    Filed under:
  • 10-25-2011 10:48 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beocenter 1 Timer
    Noah:
    Very likely - possible reasons:
    1) ML built in - but wrong option settig eg. "V.OPT 6" for using the BC1 as a link room TV
        Solution: change option to "V.OPT 1" or "V.OPT 2"
    2) NO ML-card
        Solution: try to get a (second hand) Master Link Module Type 4015
