Latest post 11-04-2011 10:03 AM by Kaa000. 10 replies.
Page 1 of 1 (11 items)
  • 10-24-2011 6:18 AM
    • Kaa000
    • Not Ranked
    • Joined on 07-15-2008
    • Posts 8
    Beocenter 9000 cd problem - no sound
    Hello,
    I couldn't find any similar cd problems from this forum (apologies if there is).
    Here is the problem:
    Cd-door slides open normally, then closes and cd starts to "play" just normally, except there is no sound at all. You can even change tracks normally, but again, there is no sound. Radio works with sound.
    This problem first occurred few weeks ago. After that first time, couple of days later, there was one time when there was normal sound, but the day after that, the problem came back. Can anybody help me with this? Thanks!
  • 10-24-2011 11:29 AM In reply to
    Re: Beocenter 9000 cd problem - no sound
    Probably someone on here who could repair it for you ... whereabouts are you based?
    Neil
  • 10-24-2011 2:06 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Try plugging your speakers into the speaker 2 sockets. If there is sound to these then it will be the mute relay which is kaputterated.
    Chris.
  • 10-24-2011 2:11 PM In reply to
    "... radio works with sound ..." Big Smile
  • 10-24-2011 2:48 PM In reply to
    • Medogsfat
    • Posts 4,045
    nobby:
    Me brain's addled nobby - full of man-flu....... Time for a large single malt & bed I think....
    Embarrassed
    Chris.
  • 10-28-2011 6:39 AM In reply to
    • Kaa000
    • Not Ranked
    • Posts 8
    Yup, mute relay is out of the question and it has been replaced couple of years ago. Me and my beocenter are located in Finland.
     Any ideas what could cause this cd-problem?
  • 10-29-2011 12:20 PM In reply to
    Grey connectors with the grey wires are sometimes suspicious. There are 2 going from the CD to main decorder PCB. wires break sometimes at the connector. With patience and small screwdriver this can be restored.
    There are also some transistors on the main CD PCB that are suspect to failure. Mainly SMD transistors.
  • 11-01-2011 10:25 AM In reply to
    hmmm ... is it a 14 bit or 16 bit player?
    which part of Finland?  I am in Helsinki next week
    Regards, Neil
  • 11-03-2011 4:08 PM In reply to
    • Kaa000
    • Not Ranked
    • Posts 8
    My technical knowledge is a bit limited, so I have no idea is it a 14 or 16bit:)
    I opened the machine up and detached the cd-player. Wires and connectors seemed fine. Then I just cleaned places a bit and closed it. And you know what, somehow cd player works fine now! Still i'm not going to get my hopes up just yet, because there is a big possibility that sound disappears again, like it did before. Hope not..
    Thanks for your help! I will get back to you if things go wrong again.
  • 11-03-2011 4:55 PM In reply to
    The CD PCB might need to be resoldered. If a soldering is bad, taking out the PCB might have solved it for the time being. But if you are a bit handy with a soldering iron it should not be a problem.
  • 11-04-2011 10:03 AM In reply to
    • Kaa000
    • Not Ranked
    • Posts 8
    I have soldered some things before, so maybe it could be done. The problem is, like I wrote before, my tech knowledge is bad and I don't quite understand what needs to be resoldered. Could you be a little more specific? :) Thanks!
