Latest post 11-01-2011 3:34 PM by Rookie. 63 replies.
Page 2 of 3 (64 items) < Previous 1 2 3 Next >
  • 10-25-2011 3:41 AM In reply to
    Re: Now what?
    @Vienna
    Thank your very much for your detailed and QUICK help!
    Danke!
    Regards Elmar
  • 10-25-2011 4:42 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Now what?
    Maab:
    In your personal opinion what would make worth to get beomaster/beosound
    as opposed to macmini
    - MOTS function
      (surprising me every day when finding similarities in music of totally different genres)
    - User interface
      (especially when "browsing" through my collection containing various types of music
       changing quite often to different "views")
    - Only one remote (Beo4/6) needed to control all functions of the system
    - And, as a matter of course: Design
    Maab:
    Would the sound be different in the two hypothetical systems?
    Never tried, but choosig a lossless format instead of a lossy one will make a difference ...
  • 10-25-2011 3:41 PM In reply to
    Re: Now what?
    Vienna:
    Maab:
    - MOTS function
    - User interface
    Maab:
    I respect Vienna greatly - he is a much better technical resource than I am
    And yes, I am biased towards Apple
    However the question of "worth" is difficult
    So B&O has MOTS, but Apple's iTunes has "Genius"; they work off different approaches - B&O's is better as it is based on an analysis of the music you own and therefore reflects your tastes and I believe exclusively your tastes.  I believe Apple's "Genius" is based comparing the music you own with the listening preferences of you and other iTunes users who have the same songs as you.  So B&O's approach provides more pleasant surprises (I suspect), and sometimes I find Apple's produces a mix stream where there are songs that I would never place side by side.  So you are getting a similar function with different results - and one comes as part of the "expense" of the Beosound 5, and the other comes "free" with the "free" iTunes software.
    On user interface, while I love the Beosound 5 wheels, I also like the search capability I get with my iPad's "Remote" app .......
    And finally, I use my Beo4 to control my iTunes (except the above searching) by using Beoport to drive LinkPlayer to drive iTunes
    So yes, the Beosound 5 IS better ... but the "worth" difference can be debated ... so please dig deeper and stay for an hour or more with your dealer's Beosound 5 to gain the best appreciation
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 10-25-2011 4:42 PM In reply to
    • Vienna
    • Posts 712
    Re: Now what?
    @ elephant
    Thank you for your kind words!
    PS: liked your previous "self-explanatory" avatar much more  Big Smile
  • 10-25-2011 6:32 PM In reply to
    • Maab
    • Not Ranked
    • Joined on 09-03-2011
    • Posts 70
    Re: Now what?
    I apologize for coming back with questions, but I really believe that my B&O dealer, as nice as he is, is not reliable...
    Can a Beosound 5 (not the encore) be on his own driving the beolab 5 digitally, without the bm5?
  • 10-25-2011 7:24 PM In reply to
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Re: Now what?
    I'm afraid not, the beomaster 5 is the guts of the system without you will just have nice head unit that can't do anything.
  • 10-25-2011 7:32 PM In reply to
    Re: Now what?
    Maab:
    If you didn't have questions, the other members would have nothing to answer! Big Smile
    Don't apologise. Ask as many as you want, that's what the forum is here for!!
    My B&O: 2009 Catalogue and Pricelist
  • 10-25-2011 8:34 PM In reply to
    • Maab
    • Not Ranked
    • Posts 70
    Re: Now what?
    Thank you very much.
  • 10-26-2011 4:45 AM In reply to
    • Vienna
    • Posts 712
    Re: Now what?
    Maab:
    without the bm5?
    It's possible the other way round.
    You can use a BeoMaster 5 without a BeoSound 5 eg. by connecting the BM5
    to a B&O TV and using the TV as display and IR-receiver.
    But then the user interface won't be the same - it then will be very similar to the one
    of BeoPlayer/BeoPort installed on a PC.
  • 10-26-2011 9:19 AM In reply to
    • Maab
    • Not Ranked
    • Posts 70
    Re: Now what?
    I'm still thinking whether to go bs5/bm5 route. I must say thou, the number of options intimidates me.
    I'm still looking for some kind of digital preamplifier that would input all sorts of digital signals and output them correctly to the bl5, all the signals not just CDs. Is this utopia of is there a device do it all that I am not aware of?
    Anyone here experienced Tact digital preamps?
  • 10-26-2011 9:33 AM In reply to
    • Vienna
    • Posts 712
    Re: Now what?
    Maab:
    Elephant's post is spot on - it's either BSd/BM5 or *G* the Big-Mac or Mini-Mac "Menu"
  • 10-26-2011 11:02 AM In reply to
    • Vienna
    • Posts 712
    Re: Now what?
    Sorry folks,
    during all the discussions about details I forgot to mention that
    a BSd/BM 5 combo connected digitally to a pair of BLb 5s requires
    an essential setting to be done first:
    Enter the "customer service menu" by pointing at "MODE"
    turn the whel down to "SETTINGS" and press ">" ">" "GO"
    turn the whel down to "SPEAKER TYPE" and press "GO"
    and select "BEOLAB 5".
  • 10-26-2011 5:30 PM In reply to
    Re: Now what?
    Maab:
    Well,
    i'd consider a B&O TV ... it can handle most of your digital signals and distribute it. I think you don't really need a preamp/AV-Reciever in the setup you described ... it can also integrate a lot of 3rd-party gear via PUC, if you want it to. That was one of the reasons i have chosen a B&O TV. It is the master on my system and reduces complexity and boxes a lot!
    Regards
    BV 7-40 BR ... Beolab 5 front ... Beolab 8000 rear ... Beolab 2 Sub ... Apple TV ... Apple NAS ... Beosound Ouverture  ... Technisat HD8-S ... Sonos ZP 90
  • 10-26-2011 5:49 PM In reply to
    • Maab
    • Not Ranked
    • Posts 70
    Re: Now what?
    I wish I knew that months ago, before I purchased one of the last Kuros on the market.
    In the future, perhaps yes, but not now.
    Simplification is indeed my goal, that's why I am a little reluctant to buy a two boxes system (bm5/bs5).
    This is my deduction after all these posts, and I thank you all indeed:
    Until settling things down, I'm receiving the speakers only next week, I will connect my iMac, from the other room, directly to the BL5. I just bought the needed converter optical >coax. And play music using the iPhone.
    For the rest I will be using the Denon avp via analog connection.
    At least for now this configurations will let me going until I decide whether to go all the way B&O.
  • 10-26-2011 6:08 PM In reply to
    • Vienna
    • Posts 712
    Re: Now what?
    Maab:
    For a non-B&O setup you'll have to order a "Sync Cable BeoLab 5 (10m)".
    The cable ensures that both loudspeakers always play at the same volume level
    when connected to non-Bang & Olufsen equipment and volume is controlled via
    your Beo 4. B&O item# 6270901.
  • 10-26-2011 6:23 PM In reply to
    • Maab
    • Not Ranked
    • Posts 70
    Re: Now what?
    Thank you. I will.
  • 10-26-2011 7:04 PM In reply to
    • Maab
    • Not Ranked
    • Posts 70
    Re: Now what?
    ...By the way: can a beomaster 5 alone, without bs5, integrate with a Kuro pioneer?
  • 10-26-2011 7:49 PM In reply to
    • Vienna
    • Posts 712
    Re: Now what?
    Maab:
    If the Kuro can be used as a monitor (VGA/DVI) it should be possible.
    You'll need an external B&O IR-receiver - no sync-cable - and we're back to powerlink + SPDIF  Smile.
    Download the BeoMaster 5 Setup/User-Guide from B&O to get informations how the user interface
    will be looking like on a TV or computer screen.
    http://www.bang-olufsen.com/UserFiles/File/ug/BeoMaster5/beomaster_5_english.pdf
    Addendum: I'd go either for a "full" BM & BSd 5 combo or, alternatively, choose the macmini solution.
  • 10-27-2011 1:51 PM In reply to
    • Maab
    • Not Ranked
    • Posts 70
    Re: Now what?
    Ok. Now I will sound like a broken disk and I apologize for that, but I can't stop thinking why, with today's technology, would not be possible to make a device that functions as a preamplifier where all the digital inputs, CDs, net radio, nas, tv, etc, can be processed/ or bypassed by the preamp and outputted via a single digital out to the speakers (in my case bl5) in PCM format. It would be simpler and all sources would be output digitally to the speakers.
    Frankly, I have hard time to understand why B&O modular system is the way it is. One broken link and it's all up in the air.
  • 10-28-2011 6:38 AM In reply to
    Re: Now what?
    There is of course gear available that would fulfill your needs. But usually you purchase one of these, because you want to benefit from their superior DAC ... and you pay for it ... in your case that would be dead money, cause the BL5 does it.
    I auditioned this one and was very pleased: http://www.ayonaudio.com/fileadmin/upload/review/skyla.pdf
    But there are others too.
    Regards
  • 10-28-2011 9:18 AM In reply to
    • Maab
    • Not Ranked
    • Posts 70
    Re: Now what?
    It could be the one, yes. But too costly to use it as a transport. And as you said its a waste with all that analog section into it.
    I will get a Beo 5/6 as universal remote.
    If I can integrate my Denon Avp I'll be fine as it can process about anything.
    Rookie, I'm curious: how come you have a beoSub in your system along the beolab5. I have 2 JL f113 and I'm thinking to sell them....
  • 10-28-2011 3:06 PM In reply to
    Re: Now what?
    You know what ... i recently sold the Beo-Sub Big Smile
    I had problems with positioning the BL5 properly ... bass was not perfect for me, and i knew they could do it better.
    So i had to remove them further away from the wall ... they really need some air around them to perform best ... therefore i had to rip off my in-wall installation to make it happen.
    Now it is quite perfect.
    Another option for you: Buy a used Beosystem 2 or 3 ... you could even get your Kuro integrated with the help of some knowledgeable people ... if you can find one.
    I personally would skip the BS5/BM5 because there are better and less expensive solutions on the market.
    Regards
  • 10-28-2011 4:46 PM In reply to
    • Maab
    • Not Ranked
    • Posts 70
    Re: Now what?
    Rookie,
    Thanks for sharing your experience.
    I normally have bass problem too in my room.
    I really hope to automatic bass to work out as I hope.
    We'll see...
  • 10-29-2011 1:50 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Re: Now what?
    Rookie:
    Regards
    If you're mainly listening to lossy files (MP3, AAC) you could even skip the Beolab 5! :)
  • 10-29-2011 5:16 AM In reply to
    Re: Now what?
    Don't believe everything they tell you.
    If you now already have bass problems don't go for the beolab5/9
    Try them before you buy them!
