1st March February 2012
Latest post 11-01-2011 3:34 PM by Rookie. 63 replies.
10-22-2011 12:28 PM
Maab
- Joined on 09-03-2011
- Posts 70
Hi,I am awaiting to the arrival of my first B&O pieces, a set of Beolab 5 and a beo4 remote. Now, I am stalled as I can't understand what's the possibilities exactly are. I looked for a preamp-processor but I can't see any listed by B&O. As now, my processor is a Denon a1hdci, tv in a Kuro, i also have a NAS and an iMac. I'd like to stream music using a NAS instead of CDs. I'd like a universal remote control to operate everything in my audio system, possibly also the tv.My understanding is that high resolution sound like sacd and BD is best if processed in my denon and sent to the BL5 in analog format. I know nothing about B&O products and I have been reading on their website about their Beolink, beomaster, beoports, etc... Those devices, although it would be nice to have them all, are too much for me to buy at once. So, my question: if i am to create a flawless system that incorporates non-B&O devices what should I buy first? Is there a list of universal remotes that handles B&O devices?Thank you.
elephant
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 2,215
Maab: Denon a1hdci
According to google hits, this unit is a 10 channel power amplifier ?
If so I believe you should not attach it to the BeoLab 5s as they have their own built in power amplifiers.
Maab: I looked for a preamp-processor but I can't see any listed by B&O.
The Beomasters and Beosounds and Beoports all output line level signals for BeoLab speakers (with their inbuilt power amplifiers) to amplify.
With suitable cables it may be (I am not an electrician nor a electrical/electronics engineer) to feed a BeoMaster/BeoSound/BeoPort to your Denon for driving your existing unpowered speakers.
Maab: I'd like to stream music using a NAS instead of CDs
The answer for this is either (as posted above) one of the two types of BeoSound 5, or perhaps even a BeoPort (this is relatively inexpensive!) connected to your iMac and your BeoLab 5s.
Maab: Is there a list of universal remotes that handles B&O devices?
The Beo 6 is B&Os reverse option, a B&O remote that drives the rest of your non-B&O devices ... but I do believe there are some universal remotes that support the infrared range that B&O uses as its standard (i.e. the issue is not just the commands, it is the actual signal frequency)
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
Maab: I will further investigate my options, I'm afraid....
If you want a "purist/audiophile" solution just for music, you might consider this:
Source & Data storage: BeoSound 5 & BeoMaster 5 (1TB internal HD)
Audio connections: - digitally via SPDIF from BeoMaster 5 <> BeoLab 5#1 <> BeoLab#2 (Role on BM5 must be set to from "NETMUSIC" to "CD")
- analog via fully mounted PowerLink cables necessary to send source data "telling" the BeoLab 5s if "CD" is selected to switch to the SPDIF instead of using the analog PowerLink input. And of course to transmit the sound when "NETRADIO" or "A.AUX" has been selected.
Speakers: your pair of BeoLab 5s
Remote: Beo 4 or Beo6
Alex
- New York, NY
- Posts 176
Vienna:
Audio connections:
Interesting ... I've never tried or even thought of trying this with the BeoMaster 5. I'm assuming those that have are reporting good results?
Store Manager
Bang & Olufsen Broadway
927 Broadway
New York, NY 10010
Vienna
- Posts 712
Alex:
Only working if there is NO other CD Player configured as an audio master in the ML setup (eg. a BeoSound xxxx in "A.OPT 0/1/2")!
Maab
- Posts 70
Vienna:
Thank you for your input.
That's about what I have in mind.
However, how come the Beomaster doesn't have a digital output? They say (B&O) beaolab 5 are better connected digitaly.
Also, how about a MacMini. Can it be integrated with the BeoSound 5?
Vienna
- Posts 712
Maab:
1) not true for BM5 2) true
If you prefer a "classic" CD/FM-Radio audio system - both, the BeoCenter 2 and the BeoSound 9000 have digital SPDIF and analogue PowerLink outputs. (BSd 4 and all the other audio systems have only analogue PL outs)
If you prefer a "digital age" storage/internet radio audio system - the BeoSound/BeoMaster 5 combo has SPDIF and analogue PowerLink outputs. (BSd5 Encore has only analogue PL outs)
In a B&O setup the BeoLab 5 uses the digital SPDIF input only when "CD" has been selected.
-> you have to select stored music ("NETMUSIK") via the command "CD".
-> You need a fully mounted PL cable to transmit this information from the source to the BeoLab 5s
-> All other sources eg. "NETRADIO" will still be tranmitted via the analogue PL cables.
-> To use the digital SPDIF it's EITHER a BSd5/BM5 OR a BSd 9000/BC2 - you can not use a BSd 9000/BC2 as a further audiosystem for your mainroom setup in parallel.
-> You are in dire need of a good dealer / installer - this will cost money ...
PS: For a BeoSound 9000 you should hurry up, it's the very last batch that soon will be sold out (these days?/weeks?/months?)
f5434964
- Joined on 07-21-2010
- Posts 198
Vienna:
Hello Vienna!
Is your statement true in general? So would I have to connect my BS9000 with both PL and SPDIF to listen to NETMUSIC (BM5 via ML to BS9000);
or do you mean: because of analogue ML: if one would listen to "digital" music only - without a DA-AD converter - the setup would have to be done the way you've mentioned?
At the moment I'm a little confused - always thought either PL or SPDIF....
Regards Elmar (near Graz ;-) )
Vienna
- Posts 712
f5434964:
No, read your BLb5 user/setup manual ...
Example: Main room BVi + speakers (connected to the PL outs of the TV) and a BSd 9000 (no speakers) and a BLb 3500 in a link room are connected via ML.
-> analogue sound in the main-room speakers as well as in the link room. for all sources.
If you additionaly run a SPDIF cable directly from BSd 9000 to BLb 5#1 and a SPDIF cable from BLb 5#1 to BLb5 #2 then:
ONLY if you select "CD" in the main room ("speaker 2" must also be the default setting for for audio in your BVi)
-> digital signal to the BLb 5s
if you select "AV"+"CD" or "SPEAKER"+"1/3/4/5" in the main room
-> analogue signal via ML and Powerlink
if you select "CD" in a linkroom
If, as I assume, your BM5 is connected via ML and "AUDIO MASTER" is set "OFF" you will not be able to change the "ROLE" for "NETMUSIC" from "NETMUSIC" to "CD" (because your audio master BSd 9000 still needs the commands "CD" and "RADIO")
-> NETMUSIC and NETRADIO analogue via ML
Maab
- Posts 70
Thank you Vienna, you have been very helpful. As I said I am a total novice regarding B&O products, thus I still have a few doubts:
Vienna: In a B&O setup the BeoLab 5 uses the digital SPDIF input only when "CD" has been selected.
Are you saing that all other digital sources like digital radio, Pandora, Flac have to be converted to analog in order to play on BL5? How about BD disks DTS-HD?
Vienna: -> You need a fully mounted PL cable to transmit this information from the source to the BeoLab 5s
I'm not sure I understand this... what kind of information?
Vienna: -> You are in dire need of a good dealer / installer - this will cost money ...
A B&O dealer I guess...
Vienna
- Posts 712
In a B&O setup the BeoLab 5 uses the digital SPDIF input only when "CD" has been selected. Are you saing that all other digital sources like digital radio, Pandora, Flac have to be converted to analog in order to play on BL5?
In a B&O setup - yes
the digital SPDIF input is only used if the signal comes from a "real CD player" with SPDIF out - eg. the BSd 90000
or from the BeoMaster 5 beeing set up as "AUDIO MASTER" and "ROLE" changed from "NETMUSIC" to "CD") (and there is no "classic" B&O audio system like a BeoSound 9000 in your setup)
In a full B&O Audio/Video setup processed in the processor of the TV and sent via (analogue) PowerLink to the speakers
You need a fully mounted PL cable to transmit this information from the source to the BeoLab 5s I'm not sure I understand this... what kind of information?
There are different types of PowerLink cables - you need the "thick" = fully mounted version ... to swich from analogue PL input to the digital SPDIF (RCA-CINCH) input when "CD" has been selected
You are in dire need of a good dealer / installer - this will cost money ... A B&O dealer I guess...
Yes, a B&O dealer if you are going for a mainly B&O setup. If you want to build up a setup combining B&O with different brands a B&O installer experienced in system integration could be the better choice ...
Rookie
- Joined on 07-02-2009
- Posts 149
why so complicated?
Buy a cheap second life Beosound for 300€ to start the whole system and control the volume on the BL5's ... hook it up to the BL5 via B&O powerlink cables first (DIN type) ... then connect your mac mini via digital out to your beolab 5's digital in ... press CD on your Beo 4 and make the system start playing music from you mac mini/NAS.
The BL5's will prefer the digital signal coming from the mac mini, as long as there is no CD in the Beosound CD-drive it can play.
You can use the apple "Remote" app to control and operate your itunes libraries on you mac mini.
You don't have to worry about DAC's and DSP-processing with the BL5's ... it is built-in ... and it is very good quality. Even if you implement an external DAC in front of the BL5's ... it is useless, save the money ... as it will be converted again anyways.
Btw: Congrats on the BL5's
Regards
BV 7-40 BR ... Beolab 5 front ... Beolab 8000 rear ... Beolab 2 Sub ... Apple TV ... Apple NAS ... Beosound Ouverture ... Technisat HD8-S ... Sonos ZP 90
Rookie
- Posts 149
o.k,
i see you don't operate any other B&O stuff ... then you don't need a beosound.
But i think you have to adapt to "option 1" using the Beo4 ... check your manual for this.
Regards
f5434964
- Posts 198
@vienna
Thanks for your very detailed answers! Sorry - I do not have BL5s but I thought about buying some; and yes I could go to a dealer and talk about my thoughts but within the forum I get very detailed and professional answers without feeling a "pressure" to buy something...
Ok my setup as audiomaster BS9000 MkIII with PL BL8000 MkII plus ML BM5 (BS5) in "no audiomaster" mode (a BS3200 with PL BL3 in another room - maybe ML later; TV at the moment not an option maybe later)
I would like to replace the BL8000 with eg BL5; I thought I could connect the BL5 with SPDIF to the BS9000 and everything would be fine! I do not care if the signal is transduced to analogue - I just wanted to know if ONLY SPDIF would be enough...
A BS3 only has PL outputs - so if I would add a TV PL would be the only option...?!
Regards Elmar
Vienna
- Posts 712
f5434964:
@ Elmar
No, running just a SPDIF from BSd 9000<>BLb5#1<>BLB5#2 is not enough. And you need a fully mounted PL cable to transmit additional data. These are needed to control the volume of the music-data sent through the SPDIF cable by the internal DSP of the BLb 5.
So, if you replace the BLb 8000s by BLb5s (and leave the rest of your setup unchanged) you'll have to replace existing "thin" PowerLink cables by fully mounted PowerLink cables AND aditionally run SPDIF (RCA/CINCH) cables as described in one of my previous posts.
If you want to add a TV or a BeoSystem 3 you'll probably want to use the BLb 5s for audio as well as video sound (TV set to V.OPT 2)
Then you'll have to connect the PL cables to the PL outs of the TV - but the SPDIF will still be connected to the BSd 9000. (without speakers = set to A.OPT 0).
TV, BSd 9000, BM5 and link-rooms (eg BSd 3200 + BLb3 in A.Opt 6) have to be connected via ML-cable.
Whether or not your setup includes a TV - only the the sound from "CD" will be transmitted digitally via SPDIF - all the rest of your sources will be analogue via ML and PL.
Grüße nach Graz!
Maab
- Posts 70
Hi Vienna,
I re-read some of your posts and something clicked my mind.
Regarding the fully mounted power link cable... Does that mean that even if connect a non-B&O device via spdif, like a digital preamp (tact) or a digital server (Aurender or Marantz), cannot be done direct-digital because of the impossibility to use the fully mounted Powerlink?
Sorry, if it sounds more dumb than I am. But I read some users are using the macmini, which I believe it has no powerlink connection.
Vienna
- Posts 712
Maab: I have been reading about Beosound 5 encore. I can't find info regarding whether it outputs via digital coax directly to beolab 5. The dealer says yes it does, but I can't find it written on B&O website.
@ Maab
Knowing both BeoSound 5 versions, ... let's say "quite well"
BeoSound/BeoMaster 5: 1 Digital Coax (RCA/CINCH/PHONO) output
BeoSound 5 Encore: NO Digital Coax (RCA/CINCH/PHONO) output
Vienna
- Posts 712
Maab: But I read some users are using the macmini, which I believe it has no powerlink connection.
In my posts I was mainly taking about "fully integrated" B&O audio or audio/video setups. Then the internal DSP of the BeoLab 5 is controlled via the volume data coming from the B&O audio/videosystem being transmitted through a fully mounted PowerLink cable.
If you want to use eg. a macmini (and no B&O audio/video system) Rookie's tips are absolutely valid. The internal DSP (volume control) of the BeoLab 5 is then directly controlled using a B&O remote - therefore no data from a B&O audio/videosystem are required (and also no PowerLink cables are needed)
