Latest post 02-19-2012 3:08 AM by beoandy. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • 02-10-2012 4:14 PM In reply to
    • beoandy
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Vienna
    • Posts 84
    • Gold Member
    Re: REG 2 command of Beo4 for Beo5/6 remote
    hi keith!
    its possible to get the xml file too? (avant dvd 32 rf)
    beoandy
    BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, Avant 28, BS 4500, BC 9500, etc....
  • 02-18-2012 11:38 AM In reply to
    Dear Beoworld Members,
    I am pleased to provide you with the XML file I produced to recreate the REG commands which allow it to be used to make Beovision AVANT and Beovision 7 region free.
    The one page instructions can be downloaded HERE and the associated XML file can be downloaded HERE
    Please read teh instructions very carefully before you start the procedure.
    Regards Keith....
  • 02-19-2012 3:08 AM In reply to
    • beoandy
    • Vienna
    • Posts 84
    • Gold Member
    @ keith: thank you! works great!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
