Latest post 10-19-2011 4:01 PM by kawo. 6 replies.
Page 1 of 1 (7 items)
  • 10-19-2011 3:53 AM
    • hotknife
    • Top 150 Contributor
    • Joined on 02-03-2008
    • Solingen/Germany
    • Posts 552
    Center speaker BL3 instead of BL7.1?
    Hi guys,
    yesterday I have had a little discussion with a friend. I`m planning to order the new 7-40 with BL7.1 speaker (BL7.2 is too larger for the sideboard, BL7.4 does not fit). Frontspeakers BL9, rearspeakers BL4000 MKII. My friend gave me the advice not to buy the BL7.1 but instead a single BL3. The BL3 would be of course not in the same league, but would complemend the BL9 much better than a BL7.1. Because I do not have the possiblity to listen to such a setup, I was wondering if anybody does have any expierence. I also think, it will look a little strange?
    BeoVision 8-40, ATV2, BeoSound 4, Front BeoLab 9, Rear Beolab 4000 MKII, Beo 4
  • 10-19-2011 6:47 AM In reply to
    Re: Center speaker BL3 instead of BL7.1?
    I had a similar situation and used a BL4 as a central speaker, the sound was fine (I know they are not well thought of speakers but I really like them). I then bought a 7.1 for my BV7-40 (same issues with speaker size) and it looks and sounds infinitely better.
    I used to think the BL4 looked good but looking back now there is no comparison. I can't comment on the sound of the BL3 but purely from an aesthetic point of view stick with a 7.1 if you can.
    Dan
  • 10-19-2011 7:46 AM In reply to
    • quader
    • Top 500 Contributor
    • Joined on 08-03-2007
    • West Yorkshire, UK
    • Posts 89
    • Gold Member
    i would suggest 7.4 in 5.1 setup
  • 10-19-2011 9:00 AM In reply to
    • hotknife
    • Solingen/Germany
    • Posts 552
    Quader, there is no way to playe a 7.4, because it has to be fixed vertical.
  • 10-19-2011 11:23 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Hi
    Did you not have a BV8 40 ?
    Will the BV7 40 on a wall not be an option? above the sideboard
  • 10-19-2011 2:15 PM In reply to
    • hotknife
    • Solingen/Germany
    • Posts 552
    Quader,
    yes at the moment the 8-40. The 7-40 should be fixed above the sideboard, on the the sideboard I`d like to place the speaker. I`d like to keep the sideboard because I´ve to hide AppleTV and DVB-C receiver.
  • 10-19-2011 4:01 PM In reply to
    • kawo
    • Joined on 04-17-2007
    • Posts 516
    I have tested the whole range, including BL 4000 and BL3 as center speaker. both 7-1 and 7-4 outperform the rest by far....furthermore it is quite difficult to get a single BL3.
    I would strongly recommend to stick with the 7-1...
    cheers
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
