Latest post 10-20-2011 2:35 PM by StephenRenko. 2 replies.
Page 1 of 1 (3 items)
  • 10-19-2011 1:17 AM
    Beogram 5500 Record Deck
    I would like to know if it is possible to hook up the 5500 record deck to any receiver that has DIN inputs? And if so, how do i see it has a pre-amp, or do I just assume it does if it has the DIN inputs?
  • 10-20-2011 1:38 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 5500 Record Deck
    There are two ways to tell if a preamp module is installed;
    - The slower tech way : Open the deck and take a look. It sits at the frontmost right corner.
    - The faster non-tech way : Connect the deck to an amplifier (line in/CD/AUX or similar level input) and listen.
    If the sound is fine, the preamp is present.
    If the sound is cold, harsh and at a very low level, the deck has no preamp and will need an amplifier with a phono input.
  • 10-20-2011 2:35 PM In reply to
    Is REC/PB input on a receiver the same as DIN input?
