Latest post 10-19-2011 3:55 AM by kallasr. 3 replies.
Page 1 of 1 (4 items)
  • 10-18-2011 12:35 PM
    Beosystem 2 Activating RGB on SCART Inputs
    Hi is this possible at all, have hooked up my Apple TV first gen to the Beosystem 2 first gen, everything works except for having colour (on my B&O plasma) which is missing, any clue whether I can change RGB settings for the SCART input?
    BR Robert
    Filed under: ,
  • 10-18-2011 3:01 PM In reply to
    Re: Beosystem 2 Activating RGB on SCART Inputs
    Hi Robert the sockets labelled as vmem and av (scart 1 & 2) are already RGB enabled. AV3 is not! However if I remember rightly you need a component to composite video converter to see colour. I am sure someone else can just confirm this?!
  • 10-19-2011 2:22 AM In reply to
    I checked all SCART connections and none display colour, I have purchased the JS technology converter in the link below (a rip off for what it does), unfortunately no colour yet...seriously start to doubt whether the ATV works properly, will hook it up to a PC monitor or so to see if it will show in colour at all...
    http://www.js-technology.com/product_info.php?products_id=52&osCsid=371d32e76df327b0bd7259942ea45ce8
  • 10-19-2011 3:55 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    I used to have a apple tv 1st. gen with a beosystem - used the atv hack from firecore:
    http://firecore.com/atvflash
    There are other methods as well - something like composite hack?
    Take a look at this or this (so using composite / rca to scart).
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
