1st March February 2012
Latest post 10-18-2011 8:54 AM by tournedos. 11 replies.
10-17-2011 7:58 PM
BGAndrea
- Joined on 10-18-2011
- Posts 6
Looking at getting Beogram 6500 on ebay, but it has a problem...
I am looking at getting this complete Beosystem 6500 on ebay but the TT has an issue. I spoke with the seller and he said that he tested the unit and it powered up but the arm didn't move. Then, the Beogram 6500 shut off about 5-10 seconds later. Any ideas as to what is wrong with it? Does anyone still repair these? It has the MMC2 cartridge and the guy barely used it, so I really think it's a good deal, but not sure if I could fix it. He also mentioned some sort of a string (not the belt) that is under the platter that came completely out when he took off the platter.
http://www.ebay.com/itm/270835280064?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1558.l2649#ht_1291wt_1413
Rich
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
Re: Looking at getting Beogram 6500 on ebay, but it has a problem...
I do not have personal experience with the BG6500. Two thoughts anyway:
You should be able to get it fixed by a pro for no more than $200, regardless of what's wrong with it. The real question is whether it's cosmetically near perfect.
If the MMC2 works still and has the low mileage on it the seller says, the cartridge alone should fetch between $200 and $300.
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
BGAndrea
- Posts 6
Thanks! Any recommendations for such a pro?
Rich
- Posts 1,089
Yes.
Start the process by sending Benny an email.
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
The string coming out of the unit is the string that puls the pick up arm mecanism toward the disc, if the arm does not move after pressing play the TT turns of, an easy fix, if by Benny ask to change all bands (2 if I remember right) and change electrolitic caps and do a full service, its worth it, as Rich mensioned only the MMC2 is worth a couple or more hundreds USD.
Get photos from the laterals, the white plastic tends to open at the edges if stored in humid locations, and if the owner stored his remote on the TT, the plastic cover will have a downward "sack" at the back end.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Søren Mexico
- Mexico city
- Posts 1,621
Just took a look on your link, the TT has an aluminum front, this is not normal in a white edition, the front normaly is white!!!!
Søren Mexico
- Mexico city
- Posts 1,621
The rest of his items is aluminum. I dont know if the TTs upper deck is white with aluminum front in aluminum edition.
mediabobny
- Joined on 04-19-2007
- Greenwich Village, NYC
- Posts 336
I'd actually assume that, since the cartridge is untested, it doesn't work. It's a well-know fact that with these old MMC cartridges the rubber stylus suspension dries out due to age, causing distortion or channel outage. Given this and the repair and the cosmetic flaws (see the platter), this turntable isn't worth much in my opinion.
BGAndrea
- Posts 6
It is just dust on the platter. Also, the entire unit is silver, it is just the angle of the pic. I verified all of this with seller.
BGAndrea
- Posts 6
Spoke with seller again. If arm manually placed on record, sound works so cartridge/stylus ok. The problem is just that the unit shuts off after a 5-10 seconds.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
All of the original MMC cartridges will fail some day - even if they sat unused all these years - and it can happen during the course of a few LP sides. I really wouldn't put much value on a working original MMC, other than that you won't need to get a new/refurbished one until in the unknown future, instead of right away... Of course every interested eBay buyer doesn't know this, so you'll need to pay for the privilege anyway in order to win the bidding.
The most likely problem in the Beogram you're looking at is described here, and this other thread describes why it may not be quite that simple after all.
Page 1 of 1 (12 items)
