Latest post 10-17-2011 3:53 PM by tournedos. 5 replies.
Page 1 of 1 (6 items)
  • 10-17-2011 1:42 PM
    • Nio
    • Not Ranked
    • Joined on 10-01-2011
    • Posts 61
    Encore = Linux?
    I just found this profile online:
    http://dk.linkedin.com/in/munklinde
    It states:
    Head of Department in R&D software
    Daily management of 25 highly skilled engineers.
    High level multi-site project management, with 3 scrum teams in-house,
    and several external teams, some placed abroad.
    Head of the software project for the new Beosound 5 Encore audio
    product, and the new linux-based audio software platform
    Which means there is a new linux-based audio software platform at B&O ... what will it be?
  • 10-17-2011 2:07 PM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Re: Encore = Linux?
    As your title says... It's called the Beosound 5 Encore Big Smile
  • 10-17-2011 2:38 PM In reply to
    • Nio
    • Not Ranked
    • Posts 61
    Re: Encore = Linux?
    What I am asking:
    BeoSound 5 uses Windowx XP and BeoSound 5 Encore uses Linux?
  • 10-17-2011 3:29 PM In reply to
    Re: Encore = Linux?
    Nio:
    What I am asking:
    I believe so .... there was another thread from last week that announced this
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 10-17-2011 3:44 PM In reply to
    • Nio
    • Not Ranked
    • Posts 61
    Re: Encore = Linux?
    So Encore is the way to go as it is the future ... there wont be too much updates for the old windows xp based system?
  • 10-17-2011 3:53 PM In reply to
    Re: Encore = Linux?
    These are both embedded systems. The OS underneath really doesn't have much to do with the potential development prospects of the application layer, nor should you even need to know or care what it is. B&O may well have developed an application framework that allows them to use the same code base on both platforms.
    On the contrary, I'd expect the Linux platform might become a problem for any proprietary Microsoft codecs - not that it'll be any easier for anything from Apple. I'd hope this to be a move towards open standards such as FLAC, it'll be better for everybody in the long run.
    -mika
