Latest post 11-13-2011 9:07 AM by Dillen. 7 replies.
Page 1 of 1 (8 items)
  • 10-17-2011 8:23 AM
    • thewoo
    • Not Ranked
    • Joined on 01-26-2011
    • Posts 5
    Beocenter 2200 turntable motor problem - can anyone help?
    I recently got my Beocenter 2200 out of storage - I've finally moved into a house big enough to set it up and use it!
    At first the turntable motor was stuck - when I pressed 'phono' it would try to start (you could hear the motor buzz/hum) but the turntable wouldn't move. I took the Beocenter apart and gave the motor a little twist to help it along. It worked, in that the motor now happily powers the turntable, but it now makes a continuous clicking sound when it is playing. I'm almost certain the clicking sound is coming from the motor.
    I've put a video of the problem on youtube - you can hear the clicking noise:
    http://www.youtube.com/watch?v=RFXFSUdBetw
    Can anyone advise me what to do? Have I damaged the motor? Can I replace it? Can I even get a replacement motor? Is that a horrible job?
    I'm happy enough taking the machine apart to clean it and replace belts, but my electrical skills aren't up to much.
    Thanks in advance for your help.
  • 10-21-2011 2:51 PM In reply to
    Re: Beocenter 2200 turntable motor problem - can anyone help?
    From the noise it seems that the motor "NOZZLE" is touching on the motor body. Check the motor.
    ciao ciao
    Eugenio
    Eugenio Colazzo
  • 11-01-2011 2:02 PM In reply to
    • thewoo
    • Not Ranked
    • Posts 5
    Thanks for your reply Eugenio. I've had a closer look at the motor assembly. The spindle on the motor isn't touching anything, the noise seems to be coming from inside the motor itself. I've put a video here:
    http://youtu.be/Rr-reLZXWnE
    I'm assuming that I'm going to need a new motor assembly, including the little circuit board and wires that are attached to it, from a scavenged Beocenter 2200. I don't suppose anybody has one for sale? I know it's not supposed to be one of the finest B&O's out there, but I love the thing!
    Thanks,
    Mat
  • 11-02-2011 1:08 PM In reply to
    wow! it seems to be a magnet detached from the external body. I don't have the spare part but often appears on ebay.
    Remeber that all B&O pieces are B&O.  :)
    ciao ciao
    Eugenio
    Eugenio Colazzo
  • 11-02-2011 1:25 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    This is a generic motor which was used on all B&O Beogram decks of the 1800/2000/5000/RX derivatives of the mid 1980's up to the last of the tangential trackers.
    They do appear on ebay very occasionally when someone parts out a broken turntable.
    Chris.
  • 11-03-2011 1:08 PM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I have one from a Beogram 2000.
  • 11-13-2011 6:58 AM In reply to
    • thewoo
    • Not Ranked
    • Posts 5
    Just wanted to report that it's now fixed & working perfectly! Thanks everyone for your help. And thanks Martin for sending the motor.
    Cheers,
    Mat
  • 11-13-2011 9:07 AM In reply to
    • Dillen
    • Posts 5,008
    Glad I could help.
    Don't be a stranger now.
