If the T delux is essentially the same as the K model and as there doesn't seem to be a user manual for the T model in the products section I can only go from my 2000K model.  Left side is (from L to R) Line out, Radio, Phono, mic.  Right side is A speakers L and R, B speakers L and R.  Additionally, underneath the unit are parallel US connectors Speakers A L + and com, R + and com, Ground system, Line out L + R, Radio L + R, Phono L + R.  If you're savvy with RtoR then all of these should be straightforward.
Does this look anything like what you have on your 2000T?  I'm sure some of the other tech minded guys with older RtoR machines can help more than I can and refer directly to their machines.
Dave.
									    Am I ready? I was born ready!
