Hallo Beo friends,
Over the past weeks, I have been building a Classical Music collection on the BS5. After experimenting with numerous (faulty) tagging options, I have found a satisfactory way to present my classical music on the BS5.
I wanted to share how I have tagged the files to show the library in the best possible way (for me, at least) on the BS5. Suggestions to further improve my method are very welcome!
The BS5 is very limited in display options compared to a PC-based Mediaplayer. That's why it is essential to populate the right Tags to make use of the BS5-s 4 'tabs' which are: Artists; Albums; Covers; and Titles.
1. Artists
For classical music I wanted to have 'composer' as the primary sorting option. However, the 'composer' tag is ignored by the BS5. Therefore I use the 'Artist' tag and fill it as follows e.g. for a CD with music by Bach:
'Artist' = 'Bach, Johann Sebastian' (without the ' ' of course)
This way the BS5 shows the Composers sorted alphabetically under Artists.
NB there are exceptions: for a compilation of music by different composers performed by one artist, I prefer to set the 'Artist" field to the performer. Example: the CD "Watercolours", music by different Nordic composers performed by the singer Anne Sophie von Otter, is tagged as: 'Artist' = 'Von Otter, Anne Sophie'. The names of the composers are listed in the 'Track title' field (see below).
2. Albums
Because I have already used Artist to display the composer, I need a different field for the performer(s) e.g. pianist, singer etc. I use the 'Album' tag to contain the name of the performer as well as the name of the album. Example: "Das Wohltemperierte Klavier" by Kenneth Gilbert is tagged under 'Album' as follows:
'Gilbert, K.: Das Wohltemperierte Klavier'
This way the BS5 shows the Performers sorted alphabetically under Albums.
What if there is more than 1 performer/album artist? My choice is as follows:
- two artists (Lieder, Sonata-s etc): put the artist that you consider as 'leading' in front like described above and then add the name of accompanying artist at the end of 'Album'. Example: 'Fischer-Dieskau, D.: Winterreise (+Moore, G.)'
- ensemble/chamber music: put the name of the ensemble in front e.g. 'Alban Berg Quartett: Schubert, String Quartet in C'
- for orchestral music, I put the name of the orchestra in front of 'Album' but another option is to give preference to the Conductor.
3. Covers
Just some practical tips here:
- use Album Cover of sufficient quality: minimum 300*300. 500*500 is better and looks quite pretty on the BS5. NB there is a limit to the size of Album Art that can be displayed, I don't know what is the exact limit but files > 1 MB are not displayed by the BS5.
- use 'embedded tagging' of album art, this is very convenient. NB: the BS5 shows only 1 album cover per Album, so tagging tracks of the same album with different covers is useless for the BS5 (however, it can be useful for Mediaplayers).
4. Titles
The BS5 also displays 'Track title'. I wanted to be able to meaningfully scroll through titles on the BS5, which requires specific sorting and therefore a significant amount of time-consuming tag editing of 'track title'. If you don't think this is important, you may just as well skip this point.
What I do here is best illustrated with examples for the different sorts of music.
- Lieder/songs: make sure the song titles are placed in front of the 'Track title'. So for example 'Track Title'= 'Im Abendrot ('O, wie schön ist deine Welt'), song for voice & piano, D. 799'. It was very nice to discover this way that I have 4 different versions of Schubert's 'Im Abendrot' in the Collection!
- Instrumental music: start with the type of music e.g. 'Track title' = 'Cello sonata No. 1 G-dur BWV 1028 - 1. Adagio' .
- 'cycles': keep titles together e.g. 'Das Wohltemperierte Klavier book 1, Praeludium & Fuga BWV 846', where the cycle 'Das Wohltemperierte Klavier' is clustered together under Titles on the BS5.
- option: add the name of the composer in the track title. This is useful when the album consists of music of several composers.
NB: keep the track titles concise, if they are too long the extra information is not shown anyway on the BS5 (3 lines max) and you will get problems with Windows file management (file length including folder tree structure is max 256 characters).
Hope this helps!
FYI Here's a list of Tools that I use to rip/tag/test:
Format: FLAC (lossless)
Ripping tool: Exact Audio Copy (EAC): http://www.exactaudiocopy.org/
Tagger & Mediaplayer: MediaMonkey: http://www.mediamonkey.com/
FLAC tester: Audio Tester, http://www.vuplayer.com/other.php
